Problems after harmonic damper replacement
Old Jun 29, 2019 | 05:13 PM
nschiff's Avatar
nschiff
Well I moved mine and it turned into a mess. It is fixed now. You dont need a Tech 2 but it would be easier. You can center the wheel using the analog voltage. The system will analyse and correct the digital voltage during every driving cycle. Got that info from another forum member. My issue was a ABS wiring fault.
Old Jun 30, 2019 | 11:45 AM
Dutch08's Avatar
Dutch08
Thanks for the information !
