One other thing to consider that hasnt been mentioned: a Z06 has less headroom than a standard coupe. This was the main factor that made me go coupe. At 6'4", I already scrape the roof of my coupe.
This is an interesting observation, and not something which I had read before purchasing my Z06. I was pretty set on a Z06 vs coupe, though, for some of the reasons mentioned in this thread. (I'm not planning to do a ton of upgrades)
Since replacing the foam in the driver's seat (bottom + back) my head is noticeably closer to the roof. Seat is all the way down, with a slight lift at the front, and mostly angled back. I removed the jute pad I had installed to gain an extra ~1/4" head clearance, but even still on big enough road bumps my head brushes the ceiling. I'm 6' 3" with a longer torso.
Based on your profile, you have a 2001, those are the years with more headroom. Headliner was changed in 2003 to reduce head room even more!
I swapped my 04's headliner for a 2000 FRC headliner. Mine was slightly water damaged, but man I got A LOT of extra headroom from the swap. I'm only 6'1" though.
Wow, no way! Yeah it's an '01. Can't even imagine less headroom.
Also, anecdotally I did the "side bolster mod" on my old/original seat back foam. At 6' 3" & 200lbs, with a decent amount of muscle, the side bolster mod was too tight. So I swapped in new seat back foam and used pieces of old foam to slightly improve the side bolsters. Good enough for now.
I did this back when the Z06 came out. I had a 99 coupe and thought I would just mod it up to Z06 level. I went pretty far but I was never satisfied. It was always 'just one more thing". By 2003 I gave up and ended up buying a 2003 Z06. Finally scratched that itch!
when you go to a track event (Auto X for me) it's amazing what a stock Z (with shocks and sway bar,tires) can do against heavily modded other cars !!!!
Depends on the deal you will find. You should also consider a FRC with z51 package!
I found a dirt cheap 99 base c6 with a lq9 6.0 swapped in.
In great stock condition for under 4.5k) So I took some $ and I cam it Ls 6 intake and ls 6 heads longtube and a auto trans stage3 build. I also updated the shocks to c6z06 so this combo will definitely destroy a stock Z06.
so bottom line
A deal is a deal
Portland OR?
Nobody lives there and there are no C5’s.....
Which is a joke BTW. 😊
I’m in Portland.
My coupe has Z06 springs, sway bars, Bilstein sport shocks etc.
I can’t tell you if it handles like a Z06, I’ve Never driven one. It handles better than I know how to drive it.
Stock short block with mods. Runs low 11’s in the 1/4 mile. But it’s an auto, so easier to run good 1/4 mile with.
Fun car. I drive it daily in the summer.
Ron
