Wheel Balancing Weight Location?
When I picked them up, damned if the weights weren't taped on flush up against the inner face of the hub one wheel, and maybe about an inch back from there on the other!
I haven't checked to see if they'll clear the calipers yet, but it got me thinking:
- Either the Tech doesn't have a choice in where they go, the machine says "here" and that's where they put them,
- Or they confused "Inboard" with "as far outboard as possible inside the wheel".
When balancing a set of wheels and tires how much leeway is there in the location where the weights can be taped?
Any info greatly appreciated!
Jeff
The machine when doing one set of weights (versus inner and outer lip) defaults to the middle of the wheel.
If it was an inexperienced Tech he won't adjust the settings. There is also the possibility that the guy at the counter didn't relay the message properly and the tech didn't know the intent. I'm betting this is what happened.
Thanks again!
Jeff
it wasn't always consistent either.
Who did you balance?
Personally I'd take them back and have them correct it or you will feel it. if they don't clear, which betting they won't based on how tight the C6Z brakes are on a C5
