Another P1637 Charge Fault Code
Started diagnosing today from reading other common threads. He is what I have learned so far.
Starter solenoid:
All connections are tight as far as I can tell. I have not taken off the longtubes yet, but was able to get my hand down there and nothing "felt" loose. I just replaced my starter 3 months ago, so all hardware is new down there. I went ahead and sprayed WD40 on it, but didn't change the fault.
Battery:
Obviously new battery reads 12 volts. Old battery sitting on the bench reads 11.6 volts, so obviously not a battery issue, it just needs to be charged since it was drained the other day. I used a jump box on it before I purchased the new battery.
Alternator:
Between POS battery post and alternator BATT post reads 0.60 volts
Ran jumper cable from POS battery post and alternator BATT post, problem did not go away (as I read Bill Curlee said).
Checked the pins on the plastic connector, (I'm assuming Pin D is the middle one, couldnt find any pictures stating which is which besides the schematic), and it read 12 volts.
As far as the fuseable link....I really not sure which wire on the solenoid that is, or what its suppose to look or feel like(from reading same post from Bill Curlee on an older thread).
I'm wondering if I do just need to replace the alternator?
All connections are clean and tight, zero corrosion.
However, the wires to the solenoid are pretty dirty, and I really have no idea if one of them may be bad. How can I tell if the fueseable link...whichever wire that is...has gone bad?
As a minimum, I would take apart the solenoid connections, clean the terminals and put it back together.
What does it read at the alternator's output stud?
