Radio
Old May 27, 2019 | 11:54 PM
Richard Jinderlee's Avatar
Richard Jinderlee
Default Radio
The radio (stock) in my '04 Z06 quit working. The fuse was not blown ( #5). I pulled the radio and found that no power was getting to the unit (the main plug has two orange wires and neither were hot with the ignition on). Also, there is a red wire running from the fuse box (attached to the fuse box in a manner that leads me to believe it was a factory afterthought) and terminating at the radio. This wire was not attached to anything and I could tell it never was. I am doubtful that a plug has worked loose somewhere or that a wire is broken. What could be disrupting power to the radio? Could it have something to do with the Bose speaker system?
(Fuse # 28 - Bose speaker, Relay # 45 ,- Bose speaker) -Richard Curtis
Old May 28, 2019 | 09:58 AM
rrwirsi's Avatar
rrwirsi
Did you or a PO do any modifications to the sound system? Just for the he** of it, try another fuse in #5 if you have not already done so.
Hope you find the problem.
Old May 29, 2019 | 09:48 AM
Richard Jinderlee
Replaced Fuse #5, Fuse #28, Relay #45. Nothing. Where might I find a wire diagram of the audio system?
Old May 29, 2019 | 03:20 PM
GCG's Avatar
GCG
Originally Posted by Richard Jinderlee
The radio (stock) in my '04 Z06 quit working. The fuse was not blown ( #5). I pulled the radio and found that no power was getting to the unit (the main plug has two orange wires and neither were hot with the ignition on)...
...Could it have something to do with the Bose speaker system? (Fuse # 28 - Bose speaker, Relay # 45 ,- Bose speaker)
If you already replaced/verified Fuse 5, Fuse 28 and Relay 45, then the only other one that comes to my mind is Fuse 24 that feeds CKT 40.
By your description, the 2 orange wires you mentioned should be CKT 440 (C1 - Pin 10) Battery Fused Feed and CKT 1044 (C2 - Pin 16) Serial Data Bus.
Circuit 440 is always hot through Fuse 5 and it feeds the radio and the trunk CD player. If you didn't find power at C1-Pin10 and Fuse 5 is not blown, you need to trace back the circuit to find where it is broken. Do you have power at both ends of Fuse 5?
I mentioned Fuse 24 above just to be thorough because it protects Circuit 40, not Circuit 440.
Old May 31, 2019 | 03:37 PM
Richard Jinderlee
The diagrams are very useful - thank you. It looks as though there is a plug at the back of the fuse panel for fuse #5 and the wire runs directly to the C1 plug at the radio. So either the wire is broken ( not likely ) or else the plug at the back side of the fuse panel is not making a connection for some reason. Now I must figure how to unfasten the fuse panel to gain access to the back of it. Would you know how this is done? -Richard
Old May 31, 2019 | 05:44 PM
Moved to C5 Tech.
Old Jun 1, 2019 | 03:05 PM
GCG's Avatar
GCG
...It looks as though there is a plug at the back of the fuse panel for fuse #5 and the wire runs directly to the C1 plug at the radio. So either the wire is broken ( not likely ) or else the plug at the back side of the fuse panel is not making a connection for some reason...
Could you please post some pictures?
Old Jun 6, 2019 | 03:57 PM
Richard Jinderlee
I've been incorrect in my assumption that the wire from fuse #5 goes directly to the radio via the orange wire. Fuse #5 is always hot so the radio would always work even if the accessory or ignition were off which is not the case. So, it must involve a circuit that does two things: allows the radio to only operate with the key on accessory or ignition and allows the radio to operate for a designated time after the key is removed. This would almost have to be a relay of some type. Which relay could this be? Richard
Old Jun 7, 2019 | 02:37 AM
GCG's Avatar
GCG
No, you were not incorrect. As I mentioned above when going over the schematics, Fuse 5 feeds Circuit 440, which indeed is always hot. This circuit directly provides power to the radio (via orange wire to Connector C1 - Pin 10) and the trunk CD player.
The OEM Bose headunit does not have an ACC Switched Power Input, just an always hot one, but it is controlled by the Serial Data Bus (Connector C2 - Pin 16). Unless the headunit is enabled via the Serial Data Bus when the key is on accessory or ignition, it won't operate. The Retained Accessory Power (RAP) Feature is also enabled via Serial Data Bus to allow the radio to continue playing for approximately 10 min or until a door is opened, whichever happens first, after the ignition switch is turned off.
NOTE: You had previously mentioned that radio had no power and that there was no voltage in orange wire from connector C1 - Pin 10. I asked you to double-check that and also test for voltage at both testing points on the top edge of Fuse 5, but you never replied.
You also reported what was described as a non-OEM wire with no voltage, going from Fuse 5 to C1 connector in headunit. I requested some pics from both ends of the wire to have a better idea. I don't know if you didn't read that or if you forgot, but it would be helpful.
Old Jun 11, 2019 | 02:48 PM
Richard Jinderlee
I put the radio problem on temporary hold wile I replaced the driver's window regulator assembly and an O2 sensor (P0157). Looking at the schematic, I will agree with you that the orange wire at Radio C1, pin #10 should always be hot regardless of the ignition key position. So there has to be a bad connection somewhere between the fuse #5 and Radio C1, pin #10. I pulled out the fuse panel but could not release the 3 main plugs at the back of the panel and did not want to force anything for fear of breaking something and that is where I am at presently stuck. I need the procedure for completely removing the fuse panel to gain access to the end of wire so I can trace it. Also, fuse #5 powers the remote CD changer -a feature not present in my car- however, the wiring for it may be installed. Could there be a problem where they splice together?
Old Jun 11, 2019 | 08:22 PM
GCG's Avatar
GCG
Originally Posted by GCG
...NOTE: You had previously mentioned that radio had no power and that there was no voltage in orange wire from connector C1 - Pin 10. I asked you to double-check that and also test for voltage at both testing points on the top edge of Fuse 5, but you never replied...
...So there has to be a bad connection somewhere between the fuse #5 and Radio C1, pin #10...
So I take it that the answers to my 2 requests above are that:
  • It was confirmed that Radio C1-Pin 10 doesn't have power
  • Both testing points on the top edge of Fuse 5 do have power
Anything I suggest from this point, will be based on that.
...You also reported what was described as a non-OEM wire with no voltage, going from Fuse 5 to C1 connector in headunit. I requested some pics from both ends of the wire to have a better idea. I don't know if you didn't read that or if you forgot, but it would be helpful.
Again, a couple of pictures would be helpful to assess the situation.
...Also, fuse #5 powers the remote CD changer -a feature not present in my car- however, the wiring for it may be installed. Could there be a problem where they splice together?
There's no external splice. Although both wires connect to Fuse 5, they leave the fusebox separately: the one going to the radio does so from IP Fusebox Connector C2-Pin E1, while the one going to the remote CD changer does it through IP Fusebox Connector C3-Pin E3.
...I pulled out the fuse panel but could not release the 3 main plugs at the back of the panel and did not want to force anything for fear of breaking something and that is where I am at presently stuck. I need the procedure for completely removing the fuse panel to gain access to the end of wire so I can trace it...
You could try to check continuity between Radio C1-Pin 10 and IP Fusebox C2-Pin E1 by using a needle to go through the insulation of the orange wire right before it goes into C2-Pin E1.
If you get continuity, then the open circuit is internal to the IP Fusebox, or a bad contact in C2-Pin E1, otherwise you would need to trace it back moving your testing points closer towards the radio C1 connector as you go.
Old Jul 27, 2019 | 02:01 PM
Richard Jinderlee
Default Radio fixed
I finally got power to the radio. I traced the problem to the female fuse spade connector in the interior fuse panel. To fix, I simply pried the contacts farther together with a jewelers screwdriver. It took all of one minute. Of course, removing the radio and fuse panel, tracing the circuitry, and putting it all back together took hours. The lesson is: always check the most simple things first.
Old Jul 27, 2019 | 10:10 PM
GCG's Avatar
GCG
I finally got power to the radio. I traced the problem to the female fuse spade connector in the interior fuse panel. To fix, I simply pried the contacts farther together with a jewelers screwdriver... ...The lesson is: always check the most simple things first.
Glad everything is working fine now after all this time and troubles, but I touched that in my first reply to you above in Post 4, and several times after that, and never got an answer:
If I may, something could be added to the lesson: don't skip steps when troubleshooting
To Radio
