X Pipe Question
Old Jun 3, 2019 | 10:27 PM
HT1663WB's Avatar
HT1663WB
Default X Pipe Question
Any benefit to putting an X pipe on a stock 2001 Z06? Thanks, Bill
Old Jun 4, 2019 | 05:59 AM
wscott62893's Avatar
wscott62893
Are you thinking of installing a catless or catted x pipe? Either way, if you’re retaining the factory manifolds and axle back, you’ll likely notice little to no difference. Your exhaust note will change a bit (especially if you ditch the cats) and there MIGHT be a few ponies freed up, but I’m not sure it’s worth the effort unless you’re upgrading more of the system and considering a tune. Even a mail order tune would help versus doing nothing.
Old Jun 4, 2019 | 07:07 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
The stock "H" pipe is a bit restrictive. There are a few threads on this subject.
And to echo what wscott62893 said, a quality x-pipe would improve exhaust flow, but by itself, with a stock system, probably wouldn't be worth the effort or expense.
Old Jun 4, 2019 | 07:58 AM
Spaggs's Avatar
Spaggs
I recently put one on my car, but it was one of those "while I'm in there" type deals. If I was not in that situation, I would probably wait until I had to change my clutch or something like that.
If you do go with an X-Pipe, look at the Magnaflow. It is a true X-Pipe. That's what I got and the exhaust note is a little different. Different, but I would not consider it better.
Good luck.
Spaggs
Old Jun 4, 2019 | 12:25 PM
smitty2919's Avatar
smitty2919
Go to an x pipe if not just for the better sound. I hated the stock H pipe motor boat/flutter sound...
My car
To X Pipe Question
