Driver's side door opening issue
Old Jun 4, 2019 | 07:27 PM
Harmsie's Avatar
Harmsie
1st Gear
Default Driver's side door opening issue
Newbie here, just bought a 2000 Nassau Blue convertible M6. The only issue I have is that when I open the door from the inside, I need to push it open with my shoulder, it doesn't pop open. I've searched for issues similar to this and haven't found anything. Anyone out there know what the issue may be?
Old Jun 4, 2019 | 08:54 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
hinge pins wore out or the door is mis-aligned ???
Old Jun 4, 2019 | 10:30 PM
3sACROWD's Avatar
3sACROWD
Based on your description, the door opens normal from the outside but not from the inside. If that is the case, then there is likely an issue with the linkage to the handle on the inside. I'm not sure what that looks like but that is what I would investigate.
To Driver's side door opening issue
