Is this possible...
Old Nov 6, 2002 | 09:49 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Default Is this possible...
For all of the eletronic guru's out there here is a question.
Would it be possible to construct an electronic device that would alter the shifting capabilities of the A4 with the push of a button?
You would have a totally stock shift program untill you pushed the "performance shift" button at which point it would alter line pressure, rpm shift points, torque management or whatever it needed to do.
With the electronic throttle control, maybe instead of a switch the computer could tell the tranny to go to a performance shift mode at WOT.
I don't know if any of this is feasable, I'm not an expert by any means so I have my Nomex suit on, just in case.
Old Nov 6, 2002 | 09:51 PM
Killrwheels's Avatar
Killrwheels
Default Re: Is this possible... (2k2C5)
Diablosport Predator is the closest, but semi-permanently changes it. You can remove when needed to place stock shift. My Wifes Supercharged Regal has it, but I believe it just alters redline.
Old Nov 8, 2002 | 07:58 AM
lostsoulny's Avatar
lostsoulny
Default Re: Is this possible... (Killrwheels)
I think you would need 2 PCM's ? :crazy:
To Is this possible...
