Headlight help please
Old Jun 13, 2019 | 06:48 PM
novasscnc's Avatar
novasscnc
Default Headlight help please
Have a 2003 z06 in Canada, would like to disable the dusk headlight function can pull the ebrake a hair there must be a better way thanks
Old Jun 13, 2019 | 08:02 PM
FX VETTE's Avatar
FX VETTE
Check out this old thread https://www.corvetteforum.com/forums...-sentinel.html
Old Jun 14, 2019 | 02:57 PM
Moved to C5 Tech.
Old Jun 14, 2019 | 04:07 PM
gimp's Avatar
gimp
Tech2 is your best bet. Or just leave it alone.
Edit: best non-hacky bet. You can bypass it as mentioned in an above post.
Old Jun 15, 2019 | 02:44 AM
GCG's Avatar
GCG
Using a Tech II, RPO Z49 can be deleted from the BCM to eliminate this mandatory feature in Canadian cars.
As mentioned in a link above, it can also be permanently bypassed by unplugging the Twilight Sentinel light sensor and connecting in its place a 4.7k ohms resistor.
Old Jun 18, 2019 | 08:44 PM
novasscnc's Avatar
novasscnc
Pulling relay 44 is a cooling fan relay correct? Thanks
Old Jun 19, 2019 | 12:27 AM
GCG's Avatar
GCG
Yes, it is one of the fan relays and it has nothing to do with the Twilight Sentinel. If you don't have access to a Tech-2 the easiest way to disable this in a Canadian model is by using a resistor in place of the light sensor, as mentioned above in Post 5.
To Headlight help please
