Rear Main Seal
Old Jun 14, 2019 | 10:08 PM
hornet7's Avatar
hornet7
Default Rear Main Seal
Man I'm having a hell of a time getting the read main seal plate off the engine. I have tilted to engine back and still cannot get to the bellhousing bolts and loosen. Any advise on getting the seal plate off without removing the bellhousing? A write up would be great.
Old Jun 15, 2019 | 11:44 AM
StingrayRebel's Avatar
StingrayRebel
bellhousing has to come off, I use long extensions and swivel sockets to get to some of the bolts... you can also lower the engine via the front cradle if all else fails
Old Jun 15, 2019 | 12:26 PM
hornet7's Avatar
hornet7
Default rear main seal
This morning I'm going to loosen the engine mounts and tilt the engine as far back as possible. I have no way to lower the cradle so we'll see what happens.
Old Jun 15, 2019 | 02:23 PM
hornet7's Avatar
hornet7
Ahhhhhhh, I got the bellhousing off. Loosening the Motor mounts was the trick. I tilted the engine as far back as possible and it nearly fell on me. I found the oil leak where the seal housing meets the oil pan. The hard part is over.
Old Jun 15, 2019 | 02:30 PM
StingrayRebel
Old Jun 17, 2019 | 03:03 PM
hornet7's Avatar
hornet7
New seal is in. Such fun!
Old Jun 17, 2019 | 05:27 PM
feeder82's Avatar
feeder82
Pain for sure, we used a length of rubber hose to start those really fun to get at bellhousing bolts, worked great.
Old Jun 17, 2019 | 05:49 PM
Bobtam's Avatar
Bobtam
I don’t get it. I changed my rear main seal and plate withou removing the bell housing.
Old Jun 17, 2019 | 08:02 PM
hornet7's Avatar
hornet7
Yes, I had seen that comment before and already got a rubber hose for that job.
To Rear Main Seal
