Halo tail light portion not lighting
Old Jun 16, 2019 | 09:55 AM
OUTAKTRL's Avatar
OUTAKTRL
Default Halo tail light portion not lighting
What’s up guys. I have a set of led halo tail lights with the halo mod. I noticed yesterday that one of the right side lights don’t light up the halo portion. The rest of the light works fine. All led’s light up. Does anyone know of a fix ? Or will I need a new tail light. Thx.
Old Jun 16, 2019 | 11:51 AM
OUTAKTRL's Avatar
OUTAKTRL
Nevermind my brothers. Removed the tail light and it was just a loose connection at the bulb plug. . it’s working perfectly again. Thx.
Old Jun 21, 2019 | 10:30 AM
hmmmm16417's Avatar
hmmmm16417
the radio interference is not cool. when the turn signal is on or brake applied, the radio station cuts out. I installed the ferrite beads on the wires as suggested in another thread (and by diode dynamics)..... it reduced the effect, but didn't eliminate it.
Old Jun 21, 2019 | 04:16 PM
GCG's Avatar
GCG
Couple of questions:
  • Did you install the ferrite cores as close as possible to the sockets and secured them so they can't slide away?
  • Were you able to loop all 3 wires at least once through the ferrite cores in all sockets?
If looping the wires was not possible because the wires were not long enough, try using two back-to-back cores to increase the blocking effect, as inductors in series are added up. Use a cable tie around the wires just before and after the ferrite cores to keep them in place as close to the bulb socket as possible.
I don't know what kind of ferrite you're using. It is important to use ferrite cores rated for 1 MHz - 300 MHz. We need to block noise in the VHF band.
Old Jun 21, 2019 | 04:26 PM
hmmmm16417's Avatar
hmmmm16417
I put them all over the wires LOL I'll try putting them all at the end near the light to see if that helps. i did not loop the wire, just clipped it around them.
Old Jun 22, 2019 | 01:43 AM
GCG's Avatar
GCG
What happens is that the wires act as a transmitter antenna for the RF noise that's being produced. That's why the cores need to be placed as close as possible to the sockets: to minimize the effective length of the "antenna" between the socket and the ferrite core.
If possible, try putting the wires through the core and looping them back around it and going through the core again. If this is not possible, the resulting inductance might no be enough and you might need to install 2 back-to-back cores secured with a cable tie around the wires to keep the cores against the sockets, as I told you before.
To Halo tail light portion not lighting
