C5 Corvette Flex Fuel with P59 pcm conversion
Old Jun 19, 2020 | 02:35 AM
NSFW's Avatar
NSFW
I'm pretty sure the only advantage is to get a check-engine light sooner if the sensors fail.
Old Jun 19, 2020 | 12:29 PM
aaronc7's Avatar
aaronc7
Thanks, I did a bunch of generic info google searching and couldn't find any "advantages" and such....so I pretty much came to the same conclusion.
Sounds like it's not worth worrying about running the wires to the PCM then and just disable those codes.
Just going to be moving the alternator pin and adding pin for flex fuel sensor...pretty simple for us with the blue/red connectors.
Some of the P59 ecu info you have posted on github helped me immensely map out some of the flex fuel tables, so thank you for that!
Old Jun 19, 2020 | 01:51 PM
theonlyherb's Avatar
theonlyherb
I've owned this car for a few months now if I can be of any help please let me know.
Old Jun 20, 2020 | 09:23 AM
StingrayRebel's Avatar
StingrayRebel
Originally Posted by aaronc7
I'm looking to tackle this very soon.
Regarding the O2 sensor grounding. P01 grounds the heater to chassis. P59 uses a heater ground that is grounded to the PCM.
Option 1 would be to just not change any wiring and disable any codes you get associated...seems like this is what most do, not a big deal.
Option 2: Run the ground wires from the front O2 sensor to the appropriate heater grounds into the P59 PCM.
Is there any advantage to option 2-- better O2 accuracy/control? Anyone tried it out?
this is a pretty good video on grounding
Old Jun 20, 2020 | 11:05 AM
aaronc7's Avatar
aaronc7
Thanks for the link! I'm sorta familiar with grounding stuff. It was a big topic of discussion when I was running megasquirt on my old turbo miata. Specifically how to wire the wideband to minimize the ground offset error and things like that. TLDR-- ground it to same place that the ECU is grounded. On the wideband I run now, I actually do account for ground voltage offset, I compared the digital output of the gauge to the analog signal that is wired to my gauge and adjusted the linear equation so they matched perfectly--or as close as I could get it across the normal AFR range.
Anyways back to this, it was my understanding that the sensors have 4 wires-- 12V powah, Signal, Signal ground and heater ground. So I THINK the actual signal ground is already wired back to the PCM for best possible accuracy etc. I'm not sure heater ground going back to PCM has any advantages other than simply allowing it to better monitor the status and pop a check engine light should something go out of limits.
Either way I don't think I'm gonna mess with it during my first trial run of all this stuff. Maybe a project for later.
Old Sep 4, 2020 | 07:52 PM
James Sanders's Avatar
James Sanders
Cruising
Originally Posted by TastyBacon
Sort of, but not exactly.
Read this:
https://www.facebook.com/ShorTuning/...33255476687762
There are hidden parameters in the '04 C5 OS that need to be modified, but they are not shown in the HP Tuners or EFI Live GUI. Professional tuners know what and where they are, but it is a trade secret.
I have a 2004 Z06 with the P59 OS ... it has Flex Fuel parameters but enabling them with a sensor hooked to Blue 56 on PCM does nothing. I do see a 5V reference coming out of the PCM on the Blue Pin 56 not sure that makes a difference. Also, used the Continental Flex Sensor which has slightly different pin wiring than stock.
The above reference to "hidden tables", "binary hacks", etc. may be my issue.
Is there a way for me to do this myself, or do I need to pay a "Professional Tuner" to make the needed changes?
Old Sep 5, 2020 | 10:21 AM
aaronc7's Avatar
aaronc7
A few hidden tables need to be exposed and change the values to something sane. Both HPT and EFI can do it, but I think it's a little bit of an extra charge on HPT to enable the feature. What tuning suite do you have?
https://www.corvetteforum.com/forums...uel-on-c5.html
Old Sep 5, 2020 | 09:54 PM
James Sanders
Cruising
I use HP Tuners for tuning [Beta 4.7.694] and have used an E85 Tune file for comparison and to copy in the "basic" parameters, including enabling the Flex Fuel. I also have a GM Tech 2 but it is not picking up the Alcohol PID, so far.
Old Sep 5, 2020 | 10:04 PM
aaronc7's Avatar
aaronc7
The thread I linked has all the info you need, but I don't have a table definition in XDF format so you'd have to make that yourself for use in hpt. Then once that's set up, it will expose a handful more tables. Then when you compare to a FF enabled tune, you'll see what all you need to copy over.
For example, even changing the option to "FF enable", there's still settings that define, ethanol sensor Hz at 0% composition, composition slope, etc. Which are not viewable by default and zeroed out in the C5 tune file.
I use EFIlive or else it would be a simple copy/paste fix for you.
Old Sep 5, 2020 | 10:29 PM
James Sanders
Cruising
I have never did a table definition ... let me see if I can figure it out in HP Tuners. If I can adapt your table def's, then it should be a done deal. I'll comment back on my progress/success. Thank you.
Old Sep 5, 2020 | 11:28 PM
aaronc7's Avatar
aaronc7
I'd love to have the info and tune files available for HPT, but since I don't have the software/cable I can't really test it. And from my understanding, it's a $100 fee or something for hptuners to enable custom table definitions...so again, another hurdle for me.
I was just going thru my files and I think I might have a good starting point XDF for you. Might be missing a few of the tables I defined in my EFI file, but I think it's about 80-90 percent complete and has enough table definitions to get the job done. Shoot me a PM and I can send it over.
Old Sep 6, 2020 | 05:58 PM
James Sanders
Cruising
On a good note, I was able to open the XDF files both with Tuner Pro and HP Tuners ... I see new parameters.
________________________________________ ________________________________________ _________________
Questions:
  1. As I looked over the files that you PM'd me and I am curious as to what the CTZ/CAX files are?
  2. Just to verify, are the (2) XDF files the only ones needed for getting the Flex Fuel working?
P.S. Even if the CTZ/CAX files are not needed for the Flex Fuel issue, I would still like to better understand all this so I my be able to apply this new found knowledge to other P59 short comings.
Thank you good Sir.
Old Sep 7, 2020 | 02:53 PM
  #33
James Sanders
Cruising
Houston we have success!
Aaron, the two XDF files you provided and [blackvette82] C5 E85 Tune file for settings together got this all working.
I have a few images showing the XDF files loaded in HP Tuners along with a data log showing alcohol percentage registering with the help of Jack Daniels
Proof.
Aaron, I will email the images to you since it does not look like I can upload on the site, yet.
Cheers
Old Dec 29, 2020 | 12:11 PM
  #34
mddrip's Avatar
mddrip
Has anyone seen this? Or tried this?
https://www.thetuninglab.com/product...r-99-02-f-body
The Tuning Lab is proud to release a PnP flex fuel solution for 98-02 F-body/00-04 C5 corvette vehicles. Use these kits to add the ability to run anywhere from straight gasoline to straight ethanol as well as reveal the true power potential of your setup. Forced induction applications benefit from the use of ethanol, and this kit allows you to switch between gasoline and ethanol without having to monitor your fuel content or adjust your fuel tables. This kit is 100% Plug And Play. Picture is for display purposes ONLY.
NOTE: Due to the nature of the 0411 (the PCM that comes factory with the F-body) flex fuel logic is limited to 2 bar (up to 14 psi of boost). If you plan on running more boost than that, please purchase a P59 PCM as it will allow you to run up to 30 psi of boost.
Old Dec 29, 2020 | 12:20 PM
  #35
Eric Fischer's Avatar
Eric Fischer
Originally Posted by mddrip
Correct link:
Old Dec 29, 2020 | 12:25 PM
  #36
mddrip's Avatar
mddrip
Originally Posted by Eric Fischer
thank you. I just corrected the link in my post as well.
Old Dec 31, 2020 | 06:09 AM
  #37
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Eric,Do you know if anybody used this? And if it works?
To C5 Corvette Flex Fuel with P59 pcm conversion
Old Dec 31, 2020 | 08:17 AM
  #38
Eric Fischer
Sorry Paul, I don't know a thing about it. I was only correcting the link as I noticed it was wrong (OP has since corrected his link too)
Old Dec 31, 2020 | 09:39 PM
  #39
aaronc7's Avatar
aaronc7
Not a whole lot of info on the product site..... does it include a tune of sorts included in the price? Or just the hardware?
For Corvettes and if you want to retain all functionality, P59 is the way to go
Old Jan 1, 2021 | 01:50 PM
  #40
UM Rebel's Avatar
UM Rebel
WOW! But why?
