Power Antenna help
Old Jun 19, 2019 | 05:11 PM
1978vett's Avatar
1978vett
Default Power Antenna help
I want to replace the mast on my power antenna on my 04 convertible.. I loosened the nut , the rubber grommet is very tight and I didn’t want to mess it up.. Can someone tell me the best way to get it to come off ? Thanks..
Old Jun 19, 2019 | 08:28 PM
JR-01's Avatar
JR-01
The rubber part stays on when replacing mast. Follow these instructions. Took me less than ten minutes.
http://www.101corvetteprojects.com/h...power-antenna/
Old Jun 20, 2019 | 12:30 AM
Moved to C5 Tech.
Old Jun 20, 2019 | 11:11 AM
MetalMan2's Avatar
MetalMan2
Just replaced the mast on mine last night. The old one was mostly missing (darn previous owners...), just had the sleeve and 3 inches of the largest OD section. But no cable or anything. This was it:
I disassembled the whole thing, partially for "fun" (I'm a Mechanical Engineer, after all), but also to verify everything inside looked fine. I chose to manually wind the mast cable which worked out great.
Old Jun 20, 2019 | 01:22 PM
1978vett's Avatar
1978vett
I replaced mine too , ended up taking the motor out too. Got everything back together and it works perfectly. The new mast is shorter than the original, but reception is fine.
Old Jun 20, 2019 | 01:51 PM
MetalMan2's Avatar
MetalMan2
Did you end up removing the grommet? I removed mine, took a bit of persuasion. Was more difficult to reinstall the grommet with the antenna pre-inserted in it (seemed like the best option).
Old Jun 20, 2019 | 01:56 PM
1978vett's Avatar
1978vett
No , I left it in. The grommet going into the trunk was a bit of a pain.
Old Jun 20, 2019 | 04:53 PM
bighank's Avatar
bighank
Default Replaced a broken mast years ago and had to dissasemble the motor
My mast broke with some of the mast left inside the motor, Got the motor out thru the tail light holes and drilled out the plastic rivets holding the motor together. Relubricated the motor and used 3 self tapping screws to hold the motor together. Got my new mast at ANTENNAMASTSRUS.COM for about $20. They were very helpful on the phone and have pictures and instructions on their website.
I wrote this up in detail many years ago on here so look in the archives for details, New mast still works well many years down the pike.
Old Jun 20, 2019 | 05:35 PM
1978vett's Avatar
1978vett
Thanks for the information.
To Power Antenna help
