2000 C5 coupe Corvette
Old Jun 20, 2019 | 11:37 AM
swskibum's Avatar
swskibum
1st Gear
Default 2000 C5 coupe Corvette
On my 2000 Vett ABS pump- Where on the Automatic Breaking System (ABS) pump does each breaking hydraulic tube from each wheel attach to the ABS pump. The two top nuts are larger than the four wheel nuts. that leaves two wheel nuts on each side of the pump for a total of four wheel nuts. I need the proper sequence for all six hydraulic lines / nuts. Thanks
Old Jun 20, 2019 | 01:33 PM
USAZR1's Avatar
USAZR1
If you ask this question in the correct forum, C5 Tech, you might get a better response.
Old Jun 21, 2019 | 01:41 AM
Moved to C5 Tech.
To 2000 C5 coupe Corvette
