DIC Code C1232H on 98 corvette
Old Jun 21, 2019 | 06:24 PM
WKBARLOW's Avatar
WKBARLOW
2nd Gear
Default DIC Code C1232H on 98 corvette
Service ABS SYSTEM LIGHT AND TRACTION LIGHT COME ON WHEN I GET UP TO 50 mph. Research code and led me to believe there’s a problem with my LEFT FRONT wheel spend sensor. In forums I read ay be a simple fix. Hook tire off check cable and connections. All seemed fine. Went back and reset code (erased it). BCk up to 50 mph and same problem. If I turn car off the warning lights go off. But come on again @ 50 mph and stay on until I cut off engine. Thoughts? Thanx in advance
Old Jun 22, 2019 | 05:45 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Visual inspection isn’t good enough with this problem...do you have a DVOM and know how to measure resistance and AC voltage ??
Old Jun 30, 2019 | 01:39 PM
WKBARLOW's Avatar
WKBARLOW
2nd Gear
Checked all the cable connections. All where good. Going to check the sensor itself next
Old Jul 1, 2019 | 06:13 PM
nschiff's Avatar
nschiff
The car will reset itself during every driving cycle. You cant clear it, it has to be fixed. Do what I did start with the ABS pigtail from the frame to the wheel hub. Then if necessary replace the wheel hub / bearing. You cant monitor the AC voltage without a special scan tool.
Old Jul 1, 2019 | 06:19 PM
C5 Diag's Avatar
C5 Diag
You CAN check the wheel speed sensor...it produces AC voltage and can be read with a multimeter !!
Old Jul 2, 2019 | 06:37 AM
JWM's Avatar
JWM
We appreciate your enthusiasm.
Old Jul 2, 2019 | 08:26 AM
oelarse's Avatar
oelarse
Here is also shown a way of testing the speedsensor it self with a multimeter
To DIC Code C1232H on 98 corvette
