Looking at picking up a forged 408-416-429 ls9/ls3 block will my 243 heads and stock exhaust manifolds, steam pipes , s/c and all that hook up well? Having it built 24x to make it easier.
How much power would be the return on this ? Got a decent deal it’s brand new just wondering before I go spending another 3500 on it! Built to hold over 1200hp!
I don’t know for sure about putting the cathedral heads on an LS3 block, but I wouldn’t consider it. The gen IV stuff also uses different length head bolts. I’d go ls3 top end because those heads flow great, and if you get them worked over they’ll compliment that new block well.
The LS3 manifolds are larger inside than the LS1/6 ones. You could probably save some $ and gain horsepower with a set of shorty headers that bolt to the rest of your exhaust system. I’d also get a new 4 corner steam venting kit.
How are the 243's prepped? If they are stock, then wouldn't you basically just be building an oversize LS6, with the 243's limiting your cam to .550 or so?
I have hardened zz performance push rods dual coil springs. I plan on picking up different rocker arms.
Well for the love of octane please continue to update this thread and let us know which way you decide to go and how it turns out. I've had some similar, though less courageous thoughts, in particular the 6.2 bottom with a 24X wheel and 243 heads/intake.
May want to read through here on the OEM head, just for some reference on the 243 vs. 317 heads on any short block larger than 6.0 especially if you plan to go the boasted route. Personally I would think the smaller chamber 243 head may not be the best bet if you plan a lot (say over 5-6 PSI) of boost pressure. Best bet would be the LS3 type intake and heads, but if you already have the caterdral port parts, I can understand why you may want to keep them. BTW, you will need to put LT headers on that s/c engine, just no two ways about it or you will choke you setup for sure if you are going to run anything over again say over 5-6 PSI of boot, especially with that large of a short block.
Awesome was great to look at those charts. Have to stick with the cathedral port heads and intake. I will prob just shove some high flow cats on and change the mufflers over to a slp style. Stock manifolds look they will hold up with a little porting-cleaning . With long tube headers my thoughts is you will gain air flow but loose back pressure. Losing the low end towards mid range. Maybe these take a huge toll on your rings as well. The 243 heads with the ls9 bottom end should gain a small increase in compression support a more low end mid range responses. Also I don’t track and live in Cali no headers trying to keep it legit as possible. I got a different air plenum also I plan on adding. Maybe shorty headers legal if I ever get around wanting to afford them.
So sorry that you have to deal with our friends from CARB. You might want to look into if a set of factory C6 LS7 exhaust manifolds will work on which ever heads you settle on. There maybe a chance that even the factory LS7 cats will bolt to those manifolds and still fit in the C5 chassis (with some custom down pipes). If they just happen to fit and work, then I would like to see it the Air *****, sorry I meant to say the inspectors at the emissions testing station spot them as being non-stock.
I believe it should not be of an issue as long as the parts are from a 1 year or newer corvette it’s all carb legit. At least that’s my knowledge of it. I was thinking on using some ls9 ZR1’s or my ported stockers. Either way it should make no difference on emissions testing. There direct replacements hahaha.
