Prothane grease
Old Jul 3, 2019 | 01:05 PM
thevelvetglove's Avatar
thevelvetglove
Default Prothane grease
I am replacing the bushings on my C5 with the red prothane bushings and do not have enough grease. What substitute grease can I use from the local parts house to make sure they don,t squeak. Thx
Old Jul 3, 2019 | 04:14 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I used silicone grease !!!!!
Old Jul 3, 2019 | 04:25 PM
gimp's Avatar
gimp
The green heavy duty grease will probably do okay. I imagine most any good marine grease will do.
FWIW, some say they need to re-grease every year or two to prevent squeak, others say their kits don't make noise ever. (I suspect some squeak is in the higher frequency range that older folks tend not to hear.) YMMV, depending on grease and bushing kit.
Old Jul 3, 2019 | 04:44 PM
Car Rookie's Avatar
Car Rookie
I believe you can only use silicone grease and you probably won't be able to find any locally, unless you buy a bunch of little containers from the hardware store for plumbing fixtures, try home depot or plumbing wholesale company. This is what I used.
Old Jul 3, 2019 | 05:14 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
two years later, with a bunch of DD miles and a ton of Auto X runs no squeaks !!!!!!! (silicone is still dripping out !!!)
Old Jul 3, 2019 | 05:46 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Jul 5, 2019 | 07:56 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
You can by 3 or so packs of the prothane grease right on eBay. It's all but free.
https://www.ebay.com/itm/Prothane-19...gAAOSwIgpZ3UDS
To Prothane grease
