Re: different twist on clutch/pedal/master/ problems (Gary2KC5)
The clutch is not releasing properly. You need an adj. master cylinder asap. Why did you go with DF, I dont know anyone that has used one with good results?
Re: different twist on clutch/pedal/master/ problems (FRC21)
A guy named John Lingenfelter recommended it, not to metion the gear head at the Chevy dealer and the guys at the dyno shop.
what does an adjustable M/C do? Where is it located? and how hard is it to install?
The adjustable master allows you to adjust the release point of your clutch/pp by way of threading the pushrod that attaches to your clutch pedal. There are several versions of adjustable masters ranging from modified stock to complete units(Mcloed and AP). I would recommend the Mcloed or AP unit. AP is pretty expensive. I have the Mcloed and like it.
It is located under the brake booster towards the engine. You take the inner fender panel behind the front left tire out to reach it. About 1-2hrs depending on how mechanically inclined you are. I would bleed the clutch also but they are supposed to be pre-bled.
I would also find a replacement resovoir line b/c the stock line is a little short for the job and that can lead to problems. Below is a hydraulic line I used with modified fittings.
Guys, thanks for the info...Mike great pics and follow up.
I take it that the adjustment is on the rod that attaches to the pedal?
MellowYellow, why do aftermarket clutches need the adjustable M/C?
Is it because they are so much stiffer?
[Modified by Gary2KC5, 10:45 PM 11/7/2002]
Yes, you adjust the rod under the dash. Pretty tight but not too bad.
Don't mean to answer Mellows question, but not all aftermarket clutches require adj. masters. The spec clutches do not require them and they can hold over 650rwhp/tq depending on type of disk, etc. Some clutches much be adjusted b/c the fulcrum or distance it takes from engagement to disengagement are different than stock. So for every inch you press the pedal, one clutch may have disengaged less than say, the stock clutch. This is why you want to adjust the master allowing disengament points to remain the same or close. Some clutches may also require different engagement points than stock. But being able to adjust, especially if you track the car, really lets you fine tune your setup. :cheers:
Ya, the aftermarket pressure plates have more clamping force then stock. They require more effort to engage and also need more M/C action to get them off the disc and need more clearance or the disc will drag agains the PP and it will never fully disengage.
