I messed up, need advise
PCM- P0530H. I think this is me unlplugging the sensor and plugging it back. Cleared and went away.
A/C- B0332H
B0337H
B0361HC
B0365H
I cleared the codes and they all went away. It took me twice to clear the B0361. Outside temp gauge shows correct temp, not sure how to see if inside cabin temp is working. When I cleared the codes I could hear the actuators resetting.
*Looking up those codes and I found another thread where it was suggested it might be the climate control. Car is an 04 with dual climate.
Started with 1 can, compressor on reads 25/200, compressor off looks like it tries to equalize to 80/150. I'm gonna slowly keep moving forward this time not paying so much attention to oz but the gauges.
You haven't talked a lot about where you added your oil, but it doesn't sound like that would cause you the problems you're having. I found that adding oil in the right amounts to all the components was a PITA.
Good luck!
Paul
Also like to add that not all ac systems are created equal I guess. 2 shops couldnt get this thing sorted out lol. Glad I didnt let the last shop put in a compressor for $1600 parts/labor.
If Relay 34 is fine, then you need to check voltage at Fuse 24 with key ON. Using a multimeter, check both testing points on the upper edge of the fuse: both of them should have full battery voltage.
If Relay 34 is fine and Fuse 24 has power with key ON, then something else in the controlling side of the relay is preventing the A/C clutch from engaging.
If I were in your shoes, I would like to rule out the possibility of a sensor telling the PCM not to engage the A/C clutch, or the HVAC Controller not being able to communicate with the PCM via Serial Data Bus (do you have any "No Comm" codes involving the HVAC Controller?).
I suggest testing these 2 sensors:
- Outside Temperature Sensor
- Refrigerant Pressure Sensor
The first one will prevent the clutch from engaging if the outside temperature is reported as below approximately 35°F to 40°F, and the second one will do the same if the refrigerant pressures are reported as below or above certain thresholds.
You could test the Outside Temperature Sensor using the attached table, a multimeter, a thermometer and water. A mix of water and ice should provide 32°F and if you remove the sensor from the car and submerge its tip in the water, it should read around 32.6k Ohms. Using progressively warmer water, test it at several points and check its resistance against the table below.
To check the Refrigerant Pressure Sensor, connect your A/C gauges and start the car. Read both pressures at equilibrium (they should be the same) and read the sensor's output at that pressure. Then jump Relay 34 as you did before, and read your high pressure and the sensor's output at that pressure. Compare those 2 sets of values to the ones below (courtesy of C5 Diag
) to verify if you're within the "safe zone" (where the clutch is not prevented from engaging) and if the sensor's output matches the expected values at those pressure points.Refrigerant Pressure Sensor measured back-probing its Signal (RED/BLK) and Ground (BLK) wires:
- Around 1V (it was determined that @90 psi - 1.2V )
Engine ON, A/C ON (Relay 34 jumped):
- High side @250 psi - 2.5V
- High side @290 psi - 2.9V
Over 410 psi or below 30 psi - A/C clutch won't engage.
Refrigerant Pressure Sensor:
- 5V reference (GRY)
- Signal (RED/BLK)
- Ground (BLK)
These tests won't cost you a cent and they will only take you a few minutes
