LM5C Older Version?
Old Jul 5, 2019 | 04:06 PM
Cyberdine74's Avatar
Cyberdine74
Default LM5C Older Version?
Hi, I purchased a used C5 and I know they previous owner installed a LM5C. However I am still getting the pull the key notice. I tried to do the brown wire dealio, but I don't see a brown wire coming from the LM5C. Is it supposed to have one? Is this an older one? Or am I completely misunderstanding what the brown wire dealio is?
Old Jul 5, 2019 | 07:17 PM
Gary In NM's Avatar
Gary In NM
The brown is on the LCM5, I was getting the pull key message until I did the brown wire mod. Others have said call the company and talk to them about it .
http://www.complianceparts.com You must have the older version.
Old Jul 7, 2019 | 02:45 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
As mentioned in other post, you most likely have an older LMC5 which did not have the brown wire. That's what happened to me. I called Richard at Compliance. He was very helpful. He sent me a new LMC5.
The instruction for the brown wire mod are at the bottom of this pdf. If you can't do this mod then you have an older LMC5.
File Type: pdf
To LM5C Older Version?
