No power
Old Jul 12, 2019 | 06:07 PM
Becky85's Avatar
Becky85
2nd Gear
Default No power
Reduce power
Old Jul 12, 2019 | 06:24 PM
jim993's Avatar
jim993
You need to post more info, Base or Z06, manual 6 or auto trans? What produced the reduced power indication? I assume the DIC is indicating reduced power. Is it? Did you shut down and attempt a restart? What codes are present? Check engine light? Past history of similar readouts?
Old Jul 12, 2019 | 06:29 PM
Becky85's Avatar
Becky85
2nd Gear
Base and auto trans. Reduce power, check engine. What is DIC?
Old Jul 12, 2019 | 07:11 PM
jim993's Avatar
jim993
The DIC is the Drivers Information Center readout on the instrument cluster just above the steering wheel.
What year car? Did you try a re start to see if the power returned? What precipitated the reduced power?
Check the following link from someone with a similar problem on how to read codes:
https://www.corvetteforum.com/forums...some-help.html
Old Jul 13, 2019 | 01:54 PM
mmartinez's Avatar
mmartinez
I just had the reduced power message happen, sometimes if your to quick to start the car and don't let the turn on sequence finish, you will get the reduced power message and check engine light.
I simply disconnected the battery for several minutes to reset the CEL light, also make sure your battery is fully charged, C5's do not like low battery voltage conditions that will cause lot's of problems.
To No power
