why won't 4.10 gears work?
Old Nov 8, 2002 | 02:23 PM
notSOMLs1's Avatar
notSOMLs1
6th Gear
Default why won't 4.10 gears work?
I found a set of 4.10's for the 8.25" Getrag unit. I keep reading on here that they won't "fit". Why would a company even make the gears if they don't fit? Or DO they fit?
Thanx in advance!
Old Nov 8, 2002 | 03:08 PM
pburant's Avatar
pburant
Default Re: why won't 4.10 gears work? (notSOMLs1)
If the 8.25 Getrag unit is the C5 rear end used for 3.42 gears (I know the C5 rear end is made by Getrag, but I don't know the size), the 4.10's will fit and work. There are several forum members who are running 4.10's. I think if your rear end had either 2.73 or 3.15 gears in it, you may need a different carrier to fit the 4.10's into.....
Try searching the archives for '4.10' or 'gears' and you will likely find all the answers to all your questions....
Old Nov 8, 2002 | 03:13 PM
notSOMLs1's Avatar
notSOMLs1
6th Gear
Default Re: why won't 4.10 gears work? (pburant)
thanks for the info. That clears some things up. Guess I just need to find out which carrier they will fit. The C5 diff is 8.25" btw.
Also I have another question..
Are ALL C5 differential assemblies the same from 97-03. I have access to a core that I can build up with the 4.10's. and would like to just swap the whole thing in.
How much do places normally charge for a differential unit with 4.10 already installed?
I've already done some searching, but it looks liek I need to do more.
Thanks!!!
Old Nov 8, 2002 | 03:28 PM
pburant's Avatar
pburant
No, not all C5 carriers are the same. There are two different ones. I know the one used for 2.73 gears will not work with the 4.10's. You need the carrier that is used for the 3.42 gears for 4.10's. I'm not sure which carrier is used for the 3.15 gears.
Old Nov 8, 2002 | 04:58 PM
notSOMLs1's Avatar
notSOMLs1
6th Gear
I was asking about the differential casing itself, not the carrier.
Will a 97 casing work in a 2002, or vise-versa?
Does anyone know if 4.10's can be used on a 3.15 carrier?
Old Nov 8, 2002 | 05:14 PM
Mike Mercury's Avatar
Mike Mercury
You need the carrier that is used for the 3.15 & 3.42 gears for 4.10's. Same case for the 3.15 and 3.42.
Old Nov 8, 2002 | 07:03 PM
notSOMLs1's Avatar
notSOMLs1
6th Gear
Default Re: why won't 4.10 gears work? (Mike Mercury)
cool thanks :)
Now does anybody know the answer to my other question regarding whether or not all C5's have the same diff. casing?
TIA
Old Nov 8, 2002 | 07:05 PM
Mike Mercury
the 2.73's are the unique case. This carrier will not accept any gearing upgrades.
Old Nov 8, 2002 | 07:19 PM
KerryH's Avatar
KerryH
I can not vouch for the 2002 or 2003 but I'm sure they are the same. In any case we changed a 2001 to an earlier year, not sure which, but everything fit and bolted up the same.
Old Nov 8, 2002 | 07:39 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: why won't 4.10 gears work? (KerryH)
Actually it's not the outer case that will not hold the 4.10's .You need the 3.** series posi unit for the 4.10 upgrade.That's why all the cores need to be 3.15 or 3.42's.We have a set of 4.10's from a vendor that the 3 series case was dropped and cracked and they took all the guts out and just put it in the 2.73 case.This is what I was told by the vendor so don't kill me if the info is not correct.
To why won't 4.10 gears work?
