Refrigerant blowing out at compressor
Old Jul 18, 2019 | 04:25 PM
justinfields18's Avatar
justinfields18
Cruising
Default Refrigerant blowing out at compressor
I installed LTs a couple months ago and they melted a hole through my AC line coming from the dryer, and I just now got around to replacing the line and recharging the system.
Everything went fine until I actually started to recharge the system. I got about a can of refrigerant in and then it sunddenly started spraying out where the line meets the compressor. The line I got was a replacement from rockauto and came with O-rings to seal against the compressor, but obviously something is wrong as they can’t hold enough pressure for the system.
Any help or advice would be appreciated
Old Jul 18, 2019 | 07:10 PM
jamieo's Avatar
jamieo
You didn't by chance happen to leave the old o-ring on the compressor did you?Just a thought,not being a smarta**!
Old Jul 18, 2019 | 07:12 PM
justinfields18
Cruising
I checked that lol. I did some digging and found another thread that listed a part number for the OEM seals and I went and bought them from the dealership and put them on, removing the o-rings that came with the aftermarket line. Pulling a vacuum on the system now and hopefully it’ll hold pressure.
Old Jul 18, 2019 | 07:34 PM
jamieo's Avatar
jamieo
I wasn't trying to sound sarcastic but I have had that issue at work.A good learning experience.Hope you get it figured out!!
To Refrigerant blowing out at compressor
