http://65.95.205.254
n/a and nit. passes in that order. The nit pass has some flat spot and dips...that was caused by clutch slippage as the new clutch was not broken in, but imagine when it is broken in!
quote:
Just curious, why does your nitrous hit seem so progressive? Do you have a progressive nitrous controller on?
mostly it because my clutch is new and was slipping. My car is a M6 so the nit. is set to come on at 3000rpm and shut down at 6600 rpm and the gas petal down to the floor switches it on., along with the dash switch.
