Flywheel stuck to crankshaft!!!!
Old Jul 22, 2019 | 07:29 PM
Z06r1's Avatar
Z06r1
Cruising
Default Flywheel stuck to crankshaft!!!!
I started a clutch job last week and got down to pulling the flywheel in the first few hours only to find out 3 of the 6 bolts have stripped heads. I tried everything I could think of to get the bolts out. I tried the chisel and hammer method, impact gun, impact chisel, air hammer with a chisel, heat, cutting a slot in the head and using a screwdriver to turn it over. Nothing is working so I finally broke down and grinded the heads off the bolts, as I did not feel comfortable trying to drill out the the bolts. Now the flywheel won't come off. I tried to use a pry bar on each side to pry it off. I've also tried heating the flywheel and then spray penetrating oil to help get some lube on it. If it helps its an aluminum flywheel.
Old Jul 22, 2019 | 09:23 PM
StingrayRebel's Avatar
StingrayRebel
you probably melted the bolts to the flywheel when cutting the bolt heads off so that's why it won't move... I would try using a drill bit slightly larger than the bolt diameter and drill them from the ends until the flywheel is free, I'm also assuming your flywheel is already trashed from cutting the bolt heads off anyway and any further damage is moot at this point
Old Jul 22, 2019 | 11:00 PM
StingrayRebel
the flywheel isn't threaded so if the bolt heads are gone it should slide off, I just think the bolts and flywheel got fused together when cutting the heads off
Old Jul 23, 2019 | 12:01 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
So what shortblock (or longblock) are you planning to buy?
Old Jul 23, 2019 | 07:50 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Some jobs shouldn't be done by using the "hand grenade" method.....
Old Jul 23, 2019 | 01:25 PM
wscott62893's Avatar
wscott62893
I was going to say, what new crank are you planning to buy and who is going to rebuild your short block. But an entire new short block also works
I'm sorry OP, I shouldn't be making a joke of your misfortune. My next step would be to start drilling and get yourself some really nice easy-outs. Unfortunately, all the heat cycling/hammering/prying you've done thus far has most likely toasted your rear main seal and probably damaged the crank bearings. Not to mention potential damage to the actual crankshaft.
Best of luck with the repair. Sounds like it may be a costly one.
Old Jul 23, 2019 | 04:13 PM
Fast one's Avatar
Fast one
It might take a week of heating/oiling two or three times a day to free the flywheel, dissimilar metals in contact for a long length of time can experience galvanic corrosion which freezes the parts together. I had a large steel locknut in an aluminum outboard motor lower unit that took several weeks of heating/oiling before it was freed. Focus the heat on the aluminum flywheel because that will expand more than the steel and minimize damage to the crankshaft and seals.
To Flywheel stuck to crankshaft!!!!
