[paging] C-5 Tech
Old Nov 8, 2002 | 11:31 PM
NJVetteGuy's Avatar
NJVetteGuy
Default [paging] C-5 Tech
I was just wondering if you had an answer for this one....you replied to my earlier post about my no-code driveability problem. I logged 3 or 4 passes with autotap, and noticed that my accelerator pedal position sensor was reading all over the place. The voltage sweep checked normal using a Vantage meter, what ground does that circuit use and where is it located? My fluctuation in TPS readings directly corresponded to the mess-ups in the APP sensor readings, and my MAF readings were off as well so I know the throttle motor was moving relative to the APP sensor readings. Any and all hints would be appreciated. Thanks :cheers:
Old Nov 12, 2002 | 12:03 AM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: [paging] C-5 Tech (NJVetteGuy)
ttt
