1998 C5 Help (Charging System Fault)
Old Jul 25, 2019 | 07:30 PM
C5Vette614's Avatar
C5Vette614
Default 1998 C5 Help (Charging System Fault)
So I had a feeling something was going on with my alternator, when I would drive I would get the Charging System Fault. Which then would turn my steering very stiff, battery volts would go from mid 12s - 13s down to like 8, 9.. Also my coolant temp gets hot really quick when this would happen. Coolant sprayed in engine bay once when the coolant got overheated. I just put in a new alternator. When I started the car up it’s squealing loud. And my battery volts wouldn’t get past 9.. I noticed my harmonic balancer was wobbling too and the damn bolt was Hand Loose. So I tightened it back down. What are y’alls thoughts on this issue of mine? I’m def replacing the balancer tomorrow, any recommendations? What’s going on with the alternator or is it the power steering, could be that pulley??
Old Jul 25, 2019 | 08:41 PM
JR-01's Avatar
JR-01
Steering stiff? Overheating? Low voltage? Squealing? Sounds like your belt is slipping. A lot.
Old Jul 25, 2019 | 08:52 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
C5Vette614's Avatar
C5Vette614
What would cause the belt to do that? Just worn out? I’ll try a new belt tomorrow also.
Old Jul 25, 2019 | 08:54 PM
C5 Diag's Avatar
C5 Diag
You most likely need a new drive belt tensioner too !!
Old Jul 25, 2019 | 09:01 PM
C5Vette614's Avatar
C5Vette614
I’ll post back tomorrow if I have any news for you guys, appreciate the help!
Old Jul 26, 2019 | 01:41 AM
Moved to C5 Tech.
Old Jul 26, 2019 | 07:18 AM
C5Vette614's Avatar
C5Vette614
Thanks jack
Old Jul 26, 2019 | 11:59 AM
GCG's Avatar
GCG
...I just put in a new alternator...
Definitely this should have been looked at first before touching the alternator. There's a good chance your alternator was fine. I hope you didn't turn it in as core, but if you did, could you still get it back? I don't know if you are aware of the issues regarding replacement alternators... Plenty of horror stories. Search the forum.
Old Jul 26, 2019 | 12:03 PM
JR-01's Avatar
JR-01
If you have little car skills you should have asked someone that knows a little instead of throwing parts at it..
To 1998 C5 Help (Charging System Fault)
