Headlight motor compatibility between generations
Old Jul 31, 2019 | 12:45 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Default Headlight motor compatibility between generations
I was searching around but never found the right answer. Maybe you guys can help?
Does anyone know if the c4 headlight motors are physically capable to fit the c5? To me they look like the same motor as the c5 except for the wiring harness. I am thinking the wiring could be spliced into the c5 so long as the motor physically fits.
I'm looking at the motor here: https://www.ebay.com/itm/A-Premium-L...8AAOSwHF1b-Pwo
Any ideas?
Thank you!
Old Jul 31, 2019 | 07:30 PM
My Vette Life's Avatar
My Vette Life
Any ideas?
Thank you!
Whats wrong with yours?
Old Aug 1, 2019 | 02:01 AM
jdmvette's Avatar
jdmvette
Night Owl for life
the upper part of the motor housing with the spinning **** is wobbly, causing the motor to be unable to lift the light.
when i hold that part of the motor securely, (gold in the pic below) it raises/lowers normally.
the gear is not the issue, so i've been making due by using a wedge to keep the motor tight.
the C4 motors look the same with different wiring so wanted to see if anyone has ever tried to use them on a C5.
for ~40 shipped i may end up as the guinea pig
Old Aug 1, 2019 | 09:39 AM
GCG's Avatar
GCG
That C4 motor looks way sturdier than ours, even the completely metal ones from the first couple of years. If you go for it let us know how it goes.
In the meantime, what happened to yours is that the bent retaining tabs that hold the motor to the gear case got loose and the motor is moving in relation to the gear case. This causes gear-to-worm disengagement.
The tabs can be bent inward a bit by holding the motor on a vise and tapping the tabs in with a hammer and screwdriver or similar tool, until the motor is tightly secured to the gear case.
Old Aug 1, 2019 | 05:41 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Sweet GCG thank you! I had intended on sending this question to you directly but your PMs are full.
Thanks again
Old Aug 1, 2019 | 09:07 PM
GCG's Avatar
GCG
Glad I could be of help!
When I replaced the broken plastic gear on one of my motors, I had to resecure its tabs and everything has been perfect after that.
Your C4 motor idea is intriguing, nevertheless
Let me know how it goes.
Old Aug 1, 2019 | 10:07 PM
jdmvette's Avatar
jdmvette
Night Owl for life
looked at them again and it appears that the mounting holes are different so i won't be trying.
the "firebird" motors are pretty cheap on ebay vs the "corvette" motors even though they're the same piece.
i'll grab a new one if the tab adjustment you mentioned doesn't fix me up, GCG.
To Headlight motor compatibility between generations
