cylinder missfire
Old Aug 6, 2019 | 07:33 PM
quik36's Avatar
quik36
Default cylinder missfire
Hi, looking for some suggestions. I have a cylinder 8 misfire. Started intermittently and then became constant while driving in about a 5 minute timespan. Sets PO308. Swapped coils, plugs, plug wires, and injector. Pulled valve cover, springs look fine. Valve lift looks good. Compression is 155 psi. Leakage is 18%. Performed pressure drop test on all injectors, about 25 psi on all of them. No engine noise. No vacuum leaks. Using spark tester on all of the coils through the wires, spark is strong. Back probed the injector wires while running, signal looks good. I pulled the intake to look for carbon on the back of the valves, they are very clean. Has anyone seen a crank or cam sensor cause a single cylinder misfire? I don't have access to a scope. This is stumping me. Car is a 1998, all stock, 78K, Thanks for your suggestions in advance. Bill
Old Aug 7, 2019 | 10:43 AM
killian96ss's Avatar
killian96ss
Just guessing here, maybe there is a damaged wire on the #8 coil harness somewhere? When you swapped coils, plugs, plug wires and injector to #8 did the problem go away or did it continue to set P0308?
Steve
Old Aug 7, 2019 | 11:29 AM
quik36's Avatar
quik36
Steve
Hi Steve, The problem stayed on Cyl #8. I have a Snap-on test plug to check coil output with the wire installed, the output on all 8 was excellent.
Old Aug 7, 2019 | 11:37 AM
killian96ss
Ok, what about the #8 injector wiring? I feel like there is a bad wire somewhere causing the intermittent issue especially since fuel and spark delivery seem ok.
Steve
Old Aug 7, 2019 | 11:40 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Bill, Is this a misfire that you can actually feel or are you just getting a P0308 I'm guessing on your scan tool...what are your long term fuel trims look like right now ??
Old Aug 7, 2019 | 01:34 PM
quik36's Avatar
quik36
Definitely feel the miss. It’s there all the time. When I pull injector wires one at a time,8 is dead. I will check fuel trim when I get the intake back on. Other things I’ve tried. Using a OTC injector pulse tool, I can pulse that injector with no change to miss-fire. Makes me lean toward ignition but that checks out ok. That’s why I was wondering if the timing of the spark is off.
Old Aug 7, 2019 | 03:06 PM
C5 Diag's Avatar
C5 Diag
Yes !!...I'd say ignition misfires account for about 75% of misfires over fuel. What you can do is remove the coil packs as an assembly and disconnect C110 which sits in between coil packs 4 and 6 and using an ohm meter "shake down" the 4 connector pins between the coil pack and C110 and make sure there are no chaffed wires too...you have a 12 volt feed, engine block ground, a control wire from the PCM and a low reference (ground) which goes to the PCM also. It's best to use a scope to really see what's going on...I like to current ramp the injector circuit for current
and also make sure that the injector pintle valve is opening (picture enclosed)...you can pick up a single channel scope from AES Wave.com and I think it goes for around $300.00 or so I think. Good you did an injector balance test so you know all injectors are flowing properly.
Old Aug 13, 2019 | 12:30 PM
quik36's Avatar
quik36
To all those who sent suggestions, thank you. Finally got back to the problem, when I removed the intake I found 1 of the wires to #8 injector rubber through. When I would unplug it to check for a signal, I would apparently move it enough to un ground it and it would check ok. Running great now!
Old Aug 13, 2019 | 12:57 PM
C5 Diag's Avatar
C5 Diag
Which wire was rubbed through ???....12 volt feed or the control wire ??...in the first post you said you back probed both wires and the “signal” was good...was this using a 12 volt test light or a scope ??...glad you found the problem !!
Old Aug 15, 2019 | 12:51 PM
quik36's Avatar
quik36
It was the trigger wire. Apparently when I would unplug the injector and plug a “noid ” light in, I would move the harness enough and it would unground the wire and the noid would flash. After looking at fuel trims, the computer was trying to lean it out too. When I pulled the intake I found the rub through
Old Aug 15, 2019 | 01:21 PM
C5 Diag's Avatar
C5 Diag
By "trigger" wire do you mean the 12 volt feed ??...the pink wire ??...if it were the striped wire which is the "control" wire (PCM grounds the control wire internally) that was worn through and grounding on the engine somewhere that injector would be always be spraying fuel ...what were the fuel trims if you can remember ??....THANKS !!!...enclosed is a good video for you !!
To cylinder missfire
