Engine Vacuum problem
Old Nov 10, 2002 | 07:33 PM
c5man99's Avatar
c5man99
Default Engine Vacuum problem
I removed an experimental vacuum pump designed to relieve crankcase pressure while drag racing. It didn't pan out so I removed it........now the problem........I had connected a vac gage to the three valve cover breathers and it always read around 5 in/hg. Now, I connected hose (that used to go to my evacuation pump) to the outlet that runs from the zo6 valley cover breather to the intake manifold. Now I show 12 in/hg AND when I turn off the ignition, it sounds like a tea kettle reaching boil(Whistling)!!
Anybody have a clue what is going on?
Thanks,
