1998 A4 Hard shift
Old Aug 14, 2019 | 09:33 PM
aahrested's Avatar
aahrested
Default 1998 A4 Hard shift
Last year I purchased a rebuilt A4 from RPM for my 1998 C5. It still has very low miles, as I am a little nervous about driving it too much, because I get a very hard shift from 1st to 2nd, , causing code P1870. P1870 is suppose to be caused by wear in the control valve body, in the bore that contains the TCC isolator. When I called RPM, they assured me that the problem was in the tune, not wear, as they would have checked for that during the rebuild. They asked if I had changed diff gearing, which I had. They said that something was overlooked during the tune changing the diff ratio (2:73 to 3:42). It only shifts hard when the temp gets up around 180*, when cold, or col, all shifts are normal.
I have a very knowledgeable tuner, who insists that nothing was overlooked so, I am stuck, and was hoping someone can fill in the blanks.
Old Aug 14, 2019 | 11:42 PM
BigGun's Avatar
BigGun
Did this start with the new diff ratio or did it do it before you changed it? If it started with the diff change i would suspect the tune. The tuner needs to look and see if anything was overlooked or not just say he is sure.
