Changing timing.....
Old Aug 17, 2019 | 06:27 PM
Michael D. Brown's Avatar
Michael D. Brown
1st Gear
Default Changing timing.....
I have a 2000 c5 that has been ls6 swaped and one day it started running rough. At first I thought it was a dead cylinder but it turns out it is the car adjusting timing. It will run great then all of the sudden run poorly and a few minutes later it will run great again and it does that back and forth.I am not sure why it is doing that. I have checked for vaccum leaks and i have replaced the front two O2 sensors. I am not sure where else to check and looking for some advice. I am afraid the PCM is going bad. Also, my big issue is, it is not throwing any codes......
Old Aug 17, 2019 | 06:43 PM
3sACROWD's Avatar
3sACROWD
Verify the connections from the air filter to the intake manifold. You may be getting unmetered air into the system.
Old Aug 17, 2019 | 06:47 PM
StingrayRebel's Avatar
StingrayRebel
these cars adjust timing constantly due to varying conditions so that is normal, is the cel on?... you need to pull and check the codes to point you in the right direction and hook it up to a scanner or datalogger to see what's going on
Old Aug 17, 2019 | 11:22 PM
Moved to C5 Tech.
Old Aug 18, 2019 | 09:47 AM
Gordy M's Avatar
Gordy M
If you put a LS6 engine in the car there are numerous changes in the PCM that would needed to be made to make the car run smoothly, a scan log and dtc codes will help with the solution. If their is no disruption in the air intake, the timing.VE,Torque curve, etc of the LS6 vary greatly from the 2000. You might check with Dynamic Corvettes in Saginaw if they still do tuning on the C5
Old Aug 23, 2019 | 06:13 PM
whatyacallit's Avatar
whatyacallit
How did you come to the conclusion that it's pulling timing? Also, If say you happen to have gotten some bad gas it could be switching back and forth between the high and low spark tables if it's getting any knock. I'm thinking it's something other than the timing unless you can give good validation that it is. We need more info.
To Changing timing.....
