C5 Headlight Issue
Old Aug 22, 2019 | 01:57 PM
VDip's Avatar
VDip
6th Gear
Default C5 Headlight Issue
Hey Guys, I have an 01 Vette that's acting odd with the headlights. Last week, the driver side light would go down and then pop out a little bit so I had to turn the lights on and off again a second time to get it go down flush.
Now when I start the car, both of the headlights pop up regardless if the lights are turned off. I have to shut off the car and open the door for the lights to go back down. The driver side has also been going down flush each time now. Any ideas on what's wrong?
Old Aug 22, 2019 | 02:08 PM
v6turbo87's Avatar
v6turbo87
Check to see if any of the bump stops are missing or worn. If they are try replacing them.
Old Aug 22, 2019 | 02:23 PM
VDip's Avatar
VDip
6th Gear
Thanks, checked those out and they look good.. Just found out the issue from another thread. Somehow I activated the twilight feature.
Old Aug 22, 2019 | 05:48 PM
GCG's Avatar
GCG
Originally Posted by VDip
Hey Guys, I have an 01 Vette that's acting odd with the headlights. Last week, the driver side light would go down and then pop out a little bit so I had to turn the lights on and off again a second time to get it go down flush...
This behavior is typical of missing or damaged rubber bump stops (No. 4 in diagram below). Even if they look fine to the naked eye, they might be scored too deep. You might need to replace them (4 per side). You can get them here.
In addition to that, there is a TSB addressing those symptoms that calls for shimming the driver's side motor (No. 2 in diagram):
...Now when I start the car, both of the headlights pop up regardless if the lights are turned off. I have to shut off the car and open the door for the lights to go back down...
...Just found out the issue from another thread. Somehow I activated the twilight feature.
Twilight indeed!
Old Aug 24, 2019 | 01:46 PM
VDip's Avatar
VDip
6th Gear
Twilight indeed!
Now it's not staying down at all anymore. I made a video of what it's doing. I'm thinking I'll just order the kit with the bump stops and washers. Anything else I should be looking at it? Here's a video of what's it doing...
Old Aug 24, 2019 | 03:09 PM
GCG's Avatar
GCG
As I mentioned in my previous post, your problem with the driver's side headlight seems to fit exactly what's covered in that TSB. In addition to that, I would replace the bump stops in the passenger's side as well (just don't add spacers to the right side).
Old Aug 28, 2019 | 11:31 PM
El original's Avatar
El original
Hello VDip, Just watched your vid. You have to tell me what you use to get that crazy shine on your Corvette....WOW!!!
Old Aug 29, 2019 | 12:22 PM
VDip's Avatar
VDip
6th Gear
I just had it detailed and buffed so that's why it looks so shiny, but I do use Auto Magic 49 Body Shine after washing or just after dusting off if it's not that dirty. If you are just looking for a quick application to keep your car shiny that stuff works wonders.
To C5 Headlight Issue
