Steering Column Lock
Old Aug 28, 2019 | 09:23 AM
Tom Baldino's Avatar
Tom Baldino
6th Gear
Originally Posted by laurent_zo6
So this happens with the LMC5 installed? If so, did you do the brown wire mod?
I'm new on this thread. I did not did have the LMC5 installed unless it was part of the original recall. I did not do the brown wire mod either. I was hoping since l only get the warning and not a locked steering column that it is a programming issue.
Old Aug 29, 2019 | 01:04 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I would install the LMC5 since the work done by the dealer does not solve the problem. Here is a link that will explain it better than I can:
http://www.complianceparts.com/lmc5whoneeds1.html
Old Aug 29, 2019 | 08:10 AM
runner140*'s Avatar
runner140*
Originally Posted by rrwirsi
It is unlikely the LMC5 is faulty. More likely ( sorry, we all have been there before) the directions/connections were not followed/done correctly. Here is what I do on things that do not work. 1) I unhook every thing that was done and start over and then have someone else follow the directions and confirm the connections were done correctly. If still not working, call Richard at Compliance Parts (855-565-8388). He is #1 with customer service. Hope you find the problem.
Old Aug 30, 2019 | 02:35 AM
laurent_zo6
Based on his answers to my posts OP does not have LMC5 installed in his car.
"I'm new on this thread. I did not did have the LMC5 installed unless it was part of the original recall. I did not do the brown wire mod either. I was hoping since l only get the warning and not a locked steering column that it is a programming issue"
Old Sep 3, 2019 | 10:57 AM
Tom Baldino
6th Gear
Were can I order an LMC5 module? I tried to order one through the C5 parts listing here and it does not come up.
Old Sep 3, 2019 | 11:34 AM
bc6152's Avatar
bc6152
http://www.complianceparts.com/lmc5whoneeds1.html - Same link as posted in post#22...
Old Sep 3, 2019 | 12:38 PM
scameron78's Avatar
scameron78
Thanks, the battery is fully charged and I still get the service message every time I start the car.
When you figure how to eliminate the message please share. Contacting Richard has been a waste of time for me. I emailed compliance parts 2 weeks after I installed the LMC5 about the pull key message. No response. 2 weeks go by I send an email again with no response. Few weeks later I call and he answers. Told him the situation and he informed me the issue can be fixed. He was to send out a different unit that should work. Never received it. I gave up. 2 years later thought I'd try again. Emailed again and got a response. Reassured me this issue can be fixed. Exchanged a few emails, then nothing. In my situation he has been no help.
Old Sep 3, 2019 | 12:48 PM
Tom Baldino
6th Gear
Default Steering Column Lock
Sorry to hear this. I will post any results once I determine the course of action. I have another contact who is extremely knowledgeable in all things Corvette as he is a restorer. I posed the issue to him regarding the LMC5 and am waiting for a response before I do anything.
Old Sep 3, 2019 | 01:00 PM
c5gray's Avatar
c5gray
Default Steering column loock
Thnx everyone for the replies regarding my steering column lock problem. I reached out to Richard at Compliance Parts (very cordial). We were supposed to reconnect later, but never did. I took everything a part reinstalled the LMC5 to no avail. Bought a new connector for BCM reconnected the LMC5 and it worked
Old Sep 3, 2019 | 01:28 PM
c5gray's Avatar
c5gray
Tom, I reached out to Richard at Compliance Parts (very cordial). We were supposed to reconnect later, but never did. I took everything a part reinstalled the LMC5 to no avail. Bought a new connector for BCM reconnected the LMC5 and it worked. Green Connector was $5.00. Hope this helps
Old Sep 4, 2019 | 12:30 AM
laurent_zo6
Please give us the link or info where you bought the part. Part number and other pertinent info. Thanks.
Old Sep 4, 2019 | 10:26 AM
c5gray's Avatar
c5gray
LMC5 was purchased at Compliance Parts for $40 plus $3 Shipping and the BCM Connector was purchased at the local Chevy Dealer, Part# 12110259 $5.17
Old Sep 4, 2019 | 07:09 PM
  #33
Tom Baldino
6th Gear
Default T
Thanks for the info.
