Re: Active Handling - would I regret not getting it? (Edge 904)
I absolutely had to have an oil change last Saturday and - incredibly - it poured rain all day here in SoCal. So I went, and the AH and traction control both kicked in a couple times. Why not have it?
You'll have better resale, and it can be turned off (as I do ) when it suits me to really get on the car. For just commuting, it makes the most sense.
Active Handling already prevented an accident in my 2000 C5. It was pouring rain one day last spring. I didn't notice the big puddle as I went into a turn. I started losing the rear end when it just seemed to stop. I looked at the DIC and Active Handling was ON!.
So, hitting the AH button once turns off both AH and TC? And holding the button for 5 secs turns off only AH but leaves TC turned on?
Holding the button for 5 secs. turns off only TC, leaves on AH, it's called Competitive driving mode. I understand turning off TC prevents the 'puter from reducing throttle pressure when tractions is lost. When TC kicks in and throttle pressure reduces, it feels really weird.
I have it in my '98. I don't have any experience with the new models to compare. But I wouldn't say to avoid it. It works great for me.
The several times it's kicked in I was pushing the GO pedal way too hard (oh fun!!!), and I'd say AH made me look like a much better driver than I actual am.
Re: Active Handling - would I regret not getting it? (C5Dawg)
Time for the contrarian to check in:
I find TC and AH anoying. I drive like grandma most of the time, blissfully ignorant of conditions. But when it comes to using the machine as it was intended, I go at it with the spirit of a race driver. TC/AH seems to check in just about every time I try to hang the tail out, I have practiced this a lot (TC/AH off) on race tracks and back road corners well known to me. It is just plain anoying to have to turn it off so that I can attack 4 corners, and then turn it back on for the rest of the drive. If TC/AH were automatically disabled above 1/2 throttle openings, I would be much happier.
Re: Active Handling - would I regret not getting it? (Mitch Alsup)
I've been there and done that. My last C5 was a 99 with active handling. I do not miss it on my current Vette. When I bought my 99 I thought it was something I really need but the only time I use it is in the rain on a road corse. My current setup is a 97 with about 400rwhp and I can drive the car just fine. I feel if the back end starts coming around I know how to drive and correct it. Good luck with your C5 purchase
On the 2002 and later you can turn it on/off on the fly. Is that not the case on the earlier cars?
