Help!
Old Sep 2, 2019 | 05:22 PM
Slash1151's Avatar
Slash1151
7th Gear
Default Help!
I recently found a few codes on my car. I hope someone can give me a few ideas to resolve them. Here are the codes
u1000h
u1064h
p1518hc
po650hc
the car has a service engine light on and has said reduced power, low voltage, and charging system failure. I tested the battery and it’s showing 12 volts. The alternator test good as well. Any tips or Advice are greatly appreciated.
Old Sep 2, 2019 | 06:09 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your battery has only 12 volts ???...how was this tested ??...FULLY charged battery will be 12.66 volts...a P1518 can set because of low battery voltage !!...how old is the battery ???...if over 3 years old I would take it to your friendly parts store and have it load tested !!...how was the alternator tested ???
Old Sep 2, 2019 | 06:26 PM
Slash1151's Avatar
Slash1151
7th Gear
u1000h
u1064h
p1518hc
po650hc
I retested the battery and it showed 12.26 with the car off. I used a volt meter my father had.
Old Sep 2, 2019 | 06:27 PM
Slash1151's Avatar
Slash1151
7th Gear
I bought the battery new last year.
Old Sep 2, 2019 | 06:30 PM
C5 Diag's Avatar
C5 Diag
How was the alternator tested ??...12.26 is still low !!
Old Sep 2, 2019 | 06:44 PM
Slash1151's Avatar
Slash1151
7th Gear
I put on my trickle charger and the battery showed 70% charged. It started this today after I washed it.
Old Sep 2, 2019 | 07:10 PM
C5 Diag's Avatar
C5 Diag
After the battery charges over night read the battery voltage...like I said 12.66 volts is fully charged....if you can’t get a full charge that battery may be bad !!...measure battery voltage with car running and all the loads off..,then turn on blower, headlights, defroster etc and see what the charging voltage is with loads on.. report back !!
Old Sep 3, 2019 | 03:19 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
u1000h
u1064h
p1518hc
po650hc
You already posted this question in the C5 general Forum. Please only post in one Forum as others have also responded in the other forum.
Old Sep 4, 2019 | 07:04 PM
Slash1151's Avatar
Slash1151
7th Gear
Old Sep 4, 2019 | 07:07 PM
Slash1151's Avatar
Slash1151
7th Gear
Ok. I took the car to autozone to have the battery and alternator tested. I was told both showed to be working normally. I now have the following codes showing
P1518H
C1278H
B2860H
V1000H
U1064H
Old Sep 5, 2019 | 12:39 AM
laurent_zo6
P1518H
C1278H
B2860H
V1000H
U1064H
Look up your codes in the following link:
File Type: pdf
Old Sep 5, 2019 | 08:23 AM
C5 Diag's Avatar
C5 Diag
I would clear all those history" codes now and drive the car for a while and before you shut it off check the codes again and see if any of those DTC's are showing "current"....I'd check the battery again with your multimeter after the car has been driven and see what it reads....if it reads 12.26 volts either have a bad battery or a faulty charging system...let us know...the P1518 and C1278 are most likely tied in to one another !!...also you may have just enough juice to start the car but some of those modules may not be "happy" !!
To Help!
