C5 spark plugs?
Old Sep 2, 2019 | 07:56 PM
2000 black c5's Avatar
2000 black c5
Default C5 spark plugs?
Was about to change plugs on my 2000 C5. Bought new AC delco professional Iridium plugs.. They are all gapped out of the box at .04. Manual says gap .06. Should I re-gap to .06? Also see differing torque settings from different sources. Is 15lbs torque correct?
Thanks a million!
Old Sep 2, 2019 | 08:38 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
You are good. Unless the car is SERIOUSLY modified, your spark plug gap will make no difference.
Old Sep 2, 2019 | 08:51 PM
2000 black c5
Cold air intake and axel back Borla exhaust is all, So Assume I'm good to go with .04 gap. Thanks for your help!
Still wonder if 15 lbs torque sounds right.
Funny as I've never torqued plugs. Just snug them up and go. But picked up new torque wrench and maybe just looking to find excuse to justify purchase :-)
Although maybe I should with those aluminum heads.
Thanks again.
Old Sep 2, 2019 | 09:14 PM
MAC5's Avatar
MAC5
OEM spark plug is AC Delco 41-110 Iridium, pre-gapped at .040
11 ft. lbs torque, and a small dab of anti-seize on the threads.
Old Sep 2, 2019 | 09:28 PM
2000 black c5
Thanks! Plugs and gap good then. 11 lb torque good to know. Was concerned about that with the aluminum heads. Will go 11 lb instead of 15. Much rather have a plug come loose than stress/strip 8 plug holes! Tiny amount of anti seize as I understand too much can throw off torque reading.
Thanks again.
Old Sep 3, 2019 | 05:04 AM
Moved to C5 Tech.
To C5 spark plugs?
