Ls3 c5
Old Sep 3, 2019 | 07:32 PM
Turbo Bob's Avatar
Turbo Bob
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Default Ls3 c5
Two years ago we put in a 376/525 LS3 crate engine from Jegs. Have drag raced it ever since with no issues. I drive my car to the dragstrip race it and drive it home. On the way home about a week ago it just shut down on the highway. No check engine lights. Tried starting it just cranked. Called AAA towed me home. Scanned it no stored codes. Thought it might be the Lingenfelter conversion box TRG-002. Ordered a new one installed it cranked right up. Drove it home from the shop. Stalled about 2 miles from home. Waited to be towed. After about 35 minutes decided to pull the fuel pump relay out of the fuse block located next to the battery. Reinstalled it cranked right up. Still chasing this gremlin. Anyone have any ideas? Thanks.
Old Sep 3, 2019 | 07:50 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Hi Bob !!...it may be a crank sensor and a way to diagnose it is to see if you have any Tach movement during cranking...if you have a fuel pressure gauge turn the key to ON...see what your fuel pressure is....if the fuel pressure drops like a rock during cranking that’s another thing you can look at...I see your in Union...if you want to bring the car down to Monmouth County I can take a look at it but if it starts normally there is really nothing to check !!...if I think it’s a CKP I just hook up the scope to check the signal wire !!...oh, you can also turn the key ON and see if you can hear the fuel pump prime.
Rob
Old Sep 3, 2019 | 07:54 PM
bonesbrakr's Avatar
bonesbrakr
Best guess would be intermittent open or short somewhere in the fuel system. Maybe even a bad ground. Worst case the fuel pump is about ready to take a poop. Original fuel system????
Old Sep 3, 2019 | 07:55 PM
Turbo Bob's Avatar
Turbo Bob
Rob
So when cranking it if the tach does not move its the crank sensor? Also seems intermittent.
Old Sep 3, 2019 | 07:57 PM
Turbo Bob's Avatar
Turbo Bob
Yes original fuel pump. It almost seems heat related. When it cools down it will start and run fine.
Old Sep 3, 2019 | 08:01 PM
C5 Diag's Avatar
C5 Diag
If the Tach does NOT move it may be a crank sensor...if a bad crank sensor you will have no spark or injection pulse...pull a plug wire off a coil and see if the spark jumps...to check injection pulse connect a test light to battery POSITIVE...remove an easy injector connector...while cranking probe the striped wire...the 12 volt test light will blink dimly if you have injection pulse...no spark...no injection pulse...NO START !!
Old Sep 3, 2019 | 08:05 PM
Turbo Bob's Avatar
Turbo Bob
Got it. Thanks for the info Rob.
Old Sep 3, 2019 | 08:06 PM
C5 Diag's Avatar
C5 Diag
You can swap the fuel pump relay with the horn relay...see if the car runs ok...like I said see if you have a 2 second prime on the fuel pump with key on...I did a YouTube video on testing the fuel pump relay circuit if it comes down to that...I usually scope the pump and check current flow and RPM !!
Old Sep 3, 2019 | 08:14 PM
robmiz's Avatar
robmiz
The TRG-002 has troubleshoot indicators... with red or green light flashing.
Light emitting diode (LED) STATUS light operation/diagnostic codes:
• Solid RED indicates powered on/no input signals present (normal for key on/engine off)
• Solid GREEN indicates the TRG-002 has a valid crankshaft and camshaft signal and is in
synchronized operation
• Blinking RED indicates no crankshaft signal in with a camshaft signal detected
• Check connections at the crankshaft sensor. Check the tachometer or the engine RPM with a scan tool while cranking the engine. If no RPM is shown while cranking then the TRG-002 is not outputting a crankshaft signal.
• Blinking GREEN indicates no camshaft signal in with a crank signal detected
• The engine should start but you may sometimes have to crank the engine for a long time before it starts. You most likely do not have a proper camshaft sensor signal into the TRG- 002. Check camshaft sensor connections and wiring pin-outs.
• The ECM/PCM should set a camshaft sensor DTC.
• Blinking RED RED RED GREEN (three red blinks followed by a green blink) indicates the TRG-002 lost crank synchronization and recovered
• Usually due to electrical noise or bad sensor/wiring.
• Blinking GREEN GREEN GREEN RED (three green blinks followed by a red blink) indicates a loss of camshaft signal.
• The TRG-002 will blink either of these two last error codes on the three (3) power up cycles after the problem occurs. If the error does not occur again during those three power ups then the code will clear. If another code occurs prior to the code clearing, the older code will be cleared and the new code will be stored and displayed.
Old Sep 3, 2019 | 08:20 PM
Turbo Bob's Avatar
Turbo Bob
Thanks for the info.
Old Sep 4, 2019 | 12:33 PM
Turbo Bob's Avatar
Turbo Bob
Update. Went to the shop this morning. My friend Mike hooked up spark plug tool and fuel pressure gauge. Drove it city and highway driving for approximately 20-25 miles. Brought a new fuel pump relay along just in case.Car did not miss a beat. Fuel pressure was at 60 lbs. Getting spark. Back to the shop. Checked the fuel pump relay in the fuse block next to the battery. It seemed hot but that may be normal with a just driven hot engine. Won’t leave there until we find the problem.
Old Sep 4, 2019 | 12:56 PM
C5 Diag's Avatar
C5 Diag
If the car does does fail to start hopefully it will happen in that shop !!
Old Sep 4, 2019 | 01:05 PM
Turbo Bob's Avatar
Turbo Bob
I’m hoping Rob.
Old Sep 4, 2019 | 01:38 PM
StingrayRebel's Avatar
StingrayRebel
if you have an old relay take it apart and get one of the legs and then remove your relay and insert the spare leg into each slot for the fuel pump relay... you should feel some resistance when pushing the leg into the slots, if it's loose then that could be an issue since it isn't making good contact... you can use a dab of solder on the relay legs to make them fit tighter or get another fuse box... I have seen the fuse box disassembled and it seems like a pita to try to fix it from the inside
Old Sep 4, 2019 | 03:57 PM
Turbo Bob's Avatar
Turbo Bob
Thanks for the info Neutron82. Appreciate it.
Old Jul 8, 2025 | 12:22 PM
Drum's Avatar
Drum
1st Gear
Default No start
did you ever figure out the issue? I have a 99 with ls3 and it’s doing the exact same thing
To Ls3 c5
