Need info asap
Sep 8, 2019 | 07:59 PM
Need info asap
Hey folks. I'm broke down on my recent trip to Montana 2 hrs from home go figure.
What I need to know is below
2005 c6 caliper bolt (small one) the same for a 2002.
My caliper is sitting against the rim..top bolt broke or came out
Sep 8, 2019 | 08:10 PM
I looked up the calipers on Rock Auto, they are different part #'s. I'll keep looking to see if I can find any information on the bolts.
Sep 8, 2019 | 08:11 PM
Sep 8, 2019 | 08:12 PM
Or if anyone knows what the size of the bolt is can limp to a hardware store most likely
Sep 8, 2019 | 08:13 PM
Sep 8, 2019 | 08:14 PM
Sep 8, 2019 | 08:16 PM
Is it the bolt that attaches the caliper to the guide pins?
Sep 8, 2019 | 08:17 PM
Yes I believe so. I can slide the boot and such where that little bolt would attach to the slide pins
Sep 8, 2019 | 08:18 PM
Too bolt there
Sep 8, 2019 | 08:20 PM
It is not the big bolt that holds the caliper bracket. Just the small bolts that hold the caliper itself to the caliper bracket.
Sep 8, 2019 | 08:26 PM
From what I can find, the bolts are the same from 1988-2013 on standard corvettes.
Sep 8, 2019 | 08:29 PM
M8x1.25 is what I found for size on c5 but not sure
Sep 8, 2019 | 08:39 PM
So far, that is all I have been able to find as well.
Sep 8, 2019 | 08:51 PM
Make sure you use lock tite!!
Sep 8, 2019 | 09:00 PM
Bolt broke inside of slide pins going to haywire it forward so it doesn't touch and idle home. Middle of no where so parts ain't gonna happen lol
Sep 8, 2019 | 09:01 PM
That sucks! Good luck, hope you make it!
Sep 8, 2019 | 09:02 PM
Will put 4 ways on and go slow may take 4 hrs but do what we can better than sitting here lol
Sep 9, 2019 | 12:23 AM
Made it back no problem thanks for the help folks
Sep 10, 2019 | 07:43 PM
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Good to hear you got back anyway. If you want a source for a boat, let me know in a p.m.
