Probably Nothing But....
Old Sep 9, 2019 | 10:31 AM
RPGR90s's Avatar
RPGR90s
Default Probably Nothing But....
I have a 2000 C5 convertible that's entirely stock with 56k, manual trans.
I've noticed lately that when starting, that it doesn't fire up immediately like it did a few months ago.
  1. Turn key and it sometimes cranks for a bit before it starts.
  2. No issues with the speed that the starter spins the motor.
  3. When the problem isn't there, you barely turn the key and it fires immediately.
No diagnostic codes are present and it doesn't do it al the time, but the trend is that its increasing. Driveability, idle and overall running are always excellent.
thanks,
RPGR90s
Old Sep 9, 2019 | 10:42 AM
glbeauchamp's Avatar
glbeauchamp
Have you tried just turning the key to the on position and letting the fuel pump run for a second or two before turning the key to start? Maybe a loss of fuel pressure while when the car sits for a long time. Couldn't tell you why that could happen though.
Old Sep 9, 2019 | 11:06 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Agree 100% !!...get yourself a fuel pressure gauge and see if the fuel pressure drops after the pump primes...but a few here on the Forum recently !!
Old Sep 9, 2019 | 11:09 AM
RPGR90s's Avatar
RPGR90s
I have tried that but haven't seen a difference.
Thanks,
RPGR90s's Avatar
RPGR90s
Can do. I have a fuel pressure gauge that I can attach right to the fuel rail. Will do the test tonight.
Thanks much!
Old Sep 9, 2019 | 11:17 AM
C5 Diag's Avatar
C5 Diag
Your '00 numbers should be the same as my '01...fuel pressure should not drop more 5 psi in one minute after the key is turned off and your priming pressure should be between 55-62 psi.
Old Sep 9, 2019 | 11:24 AM
RPGR90s's Avatar
RPGR90s
You answered my next question.
thank you!
Old Sep 10, 2019 | 08:12 AM
RPGR90s's Avatar
RPGR90s
Key on, engine not started or running, fuel pressure is a steady 50psi.
Key off, 10 minutes later, fuel pressure is still sitting at 50psi.
RPGR90s
Old Sep 10, 2019 | 08:27 AM
C5 Diag's Avatar
C5 Diag
Pressure seems a little low...when was your fuel filter changed last ???
Old Sep 10, 2019 | 09:07 AM
RPGR90s's Avatar
RPGR90s
I don't think it's ever been changed. I'm the 2nd owner. FWIW, started the engine and fuel pressure is a steady 59psi.
RPGR90s
Old Sep 10, 2019 | 09:17 AM
C5 Diag's Avatar
C5 Diag
It's best to start that fuel system "diagnostic process" with a KOEO pressure reading...without some specific tooling to actually confirm the filter is clogged I'd change it...IMHO !!...does the fuel pressure drop somewhat when you rev up the engine from idle ??
Old Sep 10, 2019 | 10:06 AM
RPGR90s's Avatar
RPGR90s
I agree. I'll go with the filter change first.
No, fuel pressure is consistent through the RPM range. I have the gauge in my line of sight while sitting in the car, so it was easy to confirm.
Thanks,
RPGR90s
Old Sep 10, 2019 | 10:18 AM
C5 Diag's Avatar
C5 Diag
I'd probably want to check fuel pump power and grounds too with the low static fuel pressure...you can do a few things like checking fuel pump current flow (somewhere around 5 amps) and also voltage drop testing on that pump circuit...power and ground !!
To Probably Nothing But....
