RK Headers/Corsa Indy
Old Nov 13, 2002 | 12:02 AM
FNC80's Avatar
FNC80
St. Jude Donor '03-'04-'05
Default RK Headers/Corsa Indy
How would this setup sound? Also, how many HP can I expect from headers/exhaust/blackwing and Granatelli MAF?
Thanks :cheers:
Old Nov 13, 2002 | 12:03 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: RK Headers/Corsa Indy (FNC80)
I would stay away from the Granatelli MAF. :yesnod:
vetterdstr :cheers:
Old Nov 13, 2002 | 12:08 AM
FNC80's Avatar
FNC80
Default Re: RK Headers/Corsa Indy (vetterdstr)
How come?
Old Nov 13, 2002 | 12:59 AM
vetterdstr's Avatar
vetterdstr
The Granatelli Its not a good mod, I had the granatelli on my car till I found out that it was messing up the fuel trims and timing. Once I took it off the car ran much better. The stock MAF does a great job as it is.
vetterdstr :cheers:
Old Nov 13, 2002 | 01:41 AM
FNC80's Avatar
FNC80
Thanks.
Old Nov 13, 2002 | 09:14 AM
vetterdstr's Avatar
vetterdstr
No problem!! :) I just saved you $400... ;) The only thing My Granatelli has been good for is once the OEM MAF got wet and I installed the Granatelli as a standby so I could finish the track Event. :eek: Since then it has sat in a plastic bag in my den... :nopity
vetterdstr :cheers:
Old Nov 13, 2002 | 09:38 AM
6Speeder's Avatar
6Speeder
I'm running the RK Sport headers and Corsa Indy's. They are a good bit louder than stock but not obnoxious. They did give loud popping on decelleration, cured that with an X pipe. The cruise is nice, but still pretty loud on WOT. Everybody around KNOWS IT when you jump on it. :D
To RK Headers/Corsa Indy
