Whining noise from shifter after Differential install(It's not the diff)
I did the install myself and everything seemed fine for a few hundred miles while I broke it in.
Then a humming whining noise started happening in 3-6th gear. Not nearly as loud as when my original diff went out and the noise didn't come from the rear.
I did the shifter adjustment and it was still there. I might add that my shifter pin whouldn't drop when the gear lever was in the center of neutral. I had to almost put it in 3rd for the pin to drop all the way. No amount of wiggling would get around this so maybe that's a hint. 1st and 2nd also have a slight grinding sometimes. A search seemed to indicate that my synchros are worn.
I also lifted the car and had a friend put it through the gears while I listened next to the diff. No noise from the diff but plenty of noise right under the center tunnel. The shifter also vibrates quite a bit when the noise starts. I'm thinking something isn't aligned after I put everything back in. Does anyone have any ideas on this?
Here's a link to a couple of my videos and the rest of the thread shows the entire disassembly. It's not the same thing as a C5 rear but it's the same principle. I mean it's a rear end. They all have a nut that can come loose.
https://www.corvetteforum.com/forums...post1599473147
Leaks? Do you have any?
Transmission. Did you take anything apart (separate halves) or otherwise loosen things?
TT. Did you have that out? If so, did you check the bearings and see if they felt ok? (I know that's a crap shoot).
It seems real pronounced in one particular gear, is that 4th when it REALLY starts making the noise? (that's straight through fyi. This appears to be on the second countershaft and I'm not positive if 4th engages that or not).
#1, I'd be making sure there's fluid in both the trans and diff. That's a must. The diff "Can" pump it out. At least mine can.
Goes without saying it seems like the trans, but I can't think of what to check. I'd make sure all bolts are tight, no gaps in mating surfaces between TT/Trans/Diff.
I can't think of an easily missed thing that would cause this, but I'd almost bet it's something simple.
Hate to say it but if it were my car, I'd pull it back apart if I didn't see something obvious while checking to make sure things are tight. I had mine apart before my oil analysis came back this spring. Just ain't worth replacing major components. My taking mine apart saved me anywhere from $5k to $10k, no joking matter. Total cost, <$200, including new fluids.
2) Highly doubt you could bend the shift linkage. Mine was also a bitch going back in fyi.
3) Not engaging all the way: Highly unlikely... The ring slides forward and aft to engage two sets of spines and it's pretty much either engaged or it's not. Yes, they can be hanging on the very edge of those 'gears', whatever you want to call the splines that engage... when that would happen, they will allow that ring to wobble because it's not straight and sitting on the full circumference of those 'splines'. That's easy enough to semi-test, just be a bit more aggressive as you put it in that gear and try to 'sling' that ring into place. Even if the forks are coming up short of pushing it all the way engaged, you can sorta fling it there if you slam the shifter some. Sorta like you're throwing it into place. That is indicative of forks not having the ends on them any more. Not sure there.
4) That's a very bad noise. I would not 'deal with the noise", I'd "Deal with the noise"
5) What ATF? Strikes me GM wants a manual trans fluid, but I could be mistaken.
6) The entire shifter moves fore and aft on the mounting bolts. That's used to adjust where the center position is. Meaning, you move the shifter body, and the shift handle moves forward / backward, opposite the direction you move the body. I'm not sure what you mean by 'lock pin dropping in". Mine has a roll-pin and it isn't connected without it. No choice but to have that in place.
If there's any oil/fluid in either of them, that's not what you're looking for. I'd be expecting to see one of em dry to make that much noise. Surely you'd see a awful mess under the car if there was a substantial leak.
I mentioned the TT above, but that seemed unlikely due to the severe nature of it. I mean, those bearings in there are just along for the ride. There's got to be some other side-load to create that much noise. Most of this stuff just doesn't go bad in 100 miles? It's very strange...
Upside if you don't need to drive it far, is gears are pretty resilient. Don't abuse things and they'll survive quite a bit. I hope you don't need to take it far in the present condition though. FYI, I bet I drove mine 200 total miles with the rear pinion shaft nut loose. Not real bad at first, but slowly getting worse. Didn't have a lot of miles left in it before it was catastrophic though. Do whatever you can to avoid making that noise when driving.
