Belanger Headers?
Old Nov 13, 2002 | 08:04 AM
jeanlucpicard's Avatar
jeanlucpicard
Default Belanger Headers?
Looking at installing a set on my 2001 Vert that already has Corsa Indy cat-back setup. Any comments - pro, con - on the Belanger set?
Save The Wave :seeya :cheers: :cool:
Old Nov 13, 2002 | 11:18 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Belanger Headers? (jeanlucpicard)
I bought some used off the Forum a while back before the FLP's came out. The install is pretty easy, passenger side go in from the top and driver's side from below. Haven't re-dyno'ed the car to check RWHP but the car sounds better with the Corsa exhaust that I have. At the track, did notice that I can run more consistant 12.5-.6's, but I was expecting to maybe pick up a tenth or two.
Old Nov 13, 2002 | 11:39 AM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Belangers are well built and easily installed. seems some customers are getting more power from other brands though...
Nate
Old Nov 13, 2002 | 05:16 PM
98ISGR8's Avatar
98ISGR8
Default Re: Belanger Headers? (Nate@xtreme)
I run belengers and have no problems with them. I think the question is how much modding are you goung to do. If you plan on more c.i. than I would go with a bigger settup.
Old Nov 14, 2002 | 08:01 AM
THRAP 42's Avatar
THRAP 42
Jeanluc,
If your set on Belangers - great, if not look at the FLPs. Just oredered a set from LAPD and they are true bolt ons with no cutting. I've already got Corsa Indys installed and the FLPs will replace everything from the engine to the Corsas and include hi-flow cats, an off-road pipe (that replace the cats) and an x-pipe. Every piece (except cats) are coated and the workmanship is great. Shawn will hook you up.
later,
To Belanger Headers?
