Upper & Lower Radiator Hoses Leaking At Connection
Old Sep 23, 2019 | 01:35 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Default Upper & Lower Radiator Hoses Leaking At Connection
I was just wondering if anyone else has had this issue I'm having. I replaced my old radiator with an aluminium one a while back. I've lately been smelling some antifreeze after I drive it and it gets up to temp. It's not leaking a lot because I've never put more antifreeze in it since i installed the new radiator. Yesterday I was installing my front splitter and noticed dried anitfreeze on the cooling fan frame edges. Upon further investigation I found the upper & lower hoses are leaking at the radiator connections. My question is, has anyone with the silicone hoses ever had this problem with these hoses leaking with the aluminium radiator? I'm thinking the silicone doesn't like to seal well with the aluminium. I checked the clamps and they're all tight. Maybe a regular rubber hose would seal better? I'm going to be replacing them both soon because I hate smelling antifreeze, like most people I'm sure.
Old Sep 24, 2019 | 06:06 PM
gimp's Avatar
gimp
I take it these silicone hoses are fancy ones you installed more recently? I still have the original rubber hoses and they work fine, though of course at this age rubber will start to leak on many cars too. New rubber should last you 10-20 years and they're not too expensive. Are the silicone ones a significant upgrade?
Old Sep 24, 2019 | 06:37 PM
Ed Ramberger's Avatar
Ed Ramberger
There are lots of threads n poor sealing silicone hoses. Quite honestly, you're just better off with a good quality rubber hose for 99% of applications.
Old Sep 24, 2019 | 08:06 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
What kind of hose clamps? Original spring type or screw type? From my understanding the spring type are better because they expand and contract with the hose and aluminum and keep constant tension.
Old Sep 24, 2019 | 08:13 PM
mstromquist
I've had these hoses on for quite a few years now and they worked great with the factory radiator. They were suppose to be an "upgrade" so to speak and last a little longer then the standard rubber ones and I believed the hype at the time. Just since I've switched to the aluminium radiator it's been an issue that I've just noticed the leaking. I just placed an order with the local parts store for the factory Gates rubber ones. Pretty sure they'll work better. Thanks for the info guys.
Edit as I didn't see the latest post when I hit enter:
I also used the standard spring type clamps on all locations. I like them better too.
Old Sep 24, 2019 | 08:32 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I like T-Bolt hose clamps !!!!!
Old Sep 25, 2019 | 12:54 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
If you're having leaking issues and you're not clamping down on the flare, get some little T-Bolt clamps and those should seal everything up.
Old Sep 26, 2019 | 01:50 AM
mstromquist
Took all the recommendations and placed an order for the T-bolt clamps also. Hopefully get it all changed Sunday if everything gets here by then. Thanks
Old Sep 26, 2019 | 08:35 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've had the silicone hoses on my car for a number of years, although I still have the OE radiator. On my car, I'm using the Gates "power-grip" hose clamps. Those are the ones that work like big pieces of shrink tubing.....
Old Sep 26, 2019 | 02:15 PM
mstromquist
^^^Thanks, I'll look into those also.^^^
To Upper & Lower Radiator Hoses Leaking At Connection
