2000 C5 Coupe key fobs
Old Sep 25, 2019 | 01:09 PM
MIKEHANSON's Avatar
MIKEHANSON
Default 2000 C5 Coupe key fobs
The remote key fobs that came with my car stopped working. I changed the batteries, re-synched and reprogrammed them then they would only lock the doors. They would neither unlock the car, release the hatch nor sound the alarm. I ordered a new remote and after synching and programming it did the same thing. I then disconnected the car's battery hoping to reset everything and now I get no response at all. I cannot synch or program the new remote. Am I missing something here or has the receiver in the car died? If so, does anyone know where it's located and how expensive and difficult is it to replace? Is it even worth the effort? Thanks in advance for your insight.
Old Sep 25, 2019 | 01:44 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
It’s under the left rear upper fender just above the tire well(inside the hatch compartment.
Old Sep 25, 2019 | 01:46 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
You pay for shipping you can have my old one, I updated my system to the 01 to 04 system !!!!
Old Sep 25, 2019 | 02:33 PM
bc6152's Avatar
bc6152
You can also update your receiver to 2001-2004 MY and get new key fobs for about $10.00 on Ebay. However, you would lose the TPMS unless you also updated your sensors.
If they're old, time to do it. A new (used) receiver could run between $50. to $100.00 and the sensors around $180.00. If you plan to keep your old one, the offer from Pounder sounds pretty good...
For an updated receiver I got mine here from a wrecked 2003... www.contemporarycorvette.com GOOD LUCK with whatever you decide...
Old Sep 25, 2019 | 03:37 PM
MIKEHANSON's Avatar
MIKEHANSON
Thank You Sir! That would be great. My e-mail is hanson13740@bellsouth.net and I'm in Rusk, Tx. 150 miles East of Dallas
Old Sep 25, 2019 | 03:39 PM
MIKEHANSON's Avatar
MIKEHANSON
Thank you for the information. The deal with Pounder is too good to pass on
Old Sep 25, 2019 | 03:42 PM
MIKEHANSON's Avatar
MIKEHANSON
Thanks. Accessed from inside? Is it a matter of unplugging the old and plugging the new?
Old Sep 25, 2019 | 03:56 PM
bc6152's Avatar
bc6152
Plug and play, all the same wiring and plug.
Old Sep 25, 2019 | 04:57 PM
Moved to C5 Tech.
Old Oct 3, 2019 | 08:39 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
did it fix your issue ?????
To 2000 C5 Coupe key fobs
