Guages and windows dying ??
The rubber accordion tube between the doors is a conduit for the door WIRE HARNESS. Disconnect accordion tubes between the door and door frame. They easily pop in and out.
The door connectors live inside the hole in the DOOR FRAME "A" PILLAR. Fish the connectors out of the hole in the door frame. Yes,,, Its Short and will not pull out very far.
Disconnect the connectors and examine the male and female pins. The FEMALE pins in the connectors are easily damaged by heat and vibration and distort. When they distort, they make a POOR CONNECTION and any vibration can cause the power to that module to turn on and off rapidly. This causes the serial data buss data corruption. My ZO6 brand new purchased by ME from a dealer in 02 had bad pins and it was NEVER disturbed previously!! CRAZY!
Here is a good example of a power plug with a damaged FEMALE PIN:
The only way to properly test the female pins for proper mechanical contact with the male pin is to insert a proper size male pin into the female pin. Here is a picture of a pin that I use to test female pins:
When you insert the pin into the female pin, you should feel resistance inserting and removing it.
To fix the pin properly you should replace it BUT,,, if your careful, you can use a metal pick (I use a dental pick) and bend the metal tong back in place so that it makes positive contact with the male pin.
Female end for sure looks bent and in need of some sprucing up. Once i reconnected both and reattatched battery, i cranked the car and guages still didnt work. I wiggled these wires directly and nothint changed. Do you still think this could be the issu .
