OBD2 port questions
Old Sep 28, 2019 | 11:33 AM
SoAlVette's Avatar
SoAlVette
Default OBD2 port questions
Anyone had issues with their OBD2 port having loose connections. Before I try to remove mine and inspect it I was wondering if this is possible. I am having problems getting my Tech 2 to connect. Once I was able to get it to connect by pushing the cable hard onto the port and it connected, have not been able to since. My port is loose, maybe it's been removed before? Using new tech 2 cables and new tech 2 VCI module
Old Sep 28, 2019 | 11:53 AM
Ed Ramberger's Avatar
Ed Ramberger
Unless you have the test connectors to do a pull test, you could probably use a mirror to look up in there and see if one looks spread or otherwise different.
