What’s next for mods ?
Old Sep 30, 2019 | 12:52 AM
Skrilla's Avatar
Skrilla
Default What’s next for mods ?
I got a good CAI set up , ls6 manifold and headers/full exhaust on my 99 6 speed convertible . What would be a good next mod ? I don’t want to change the gears .
Old Sep 30, 2019 | 11:23 AM
oharal's Avatar
oharal
No idea. What are your goals? If you only want to make 400whp a supercharger or turbo are obviously poor choices.
Old Oct 1, 2019 | 11:01 AM
Skrilla's Avatar
Skrilla
I’d like to add a supercharger down the road , what is a good thing to do until then ?
Old Oct 1, 2019 | 01:34 PM
turabo87's Avatar
turabo87
I'm a fan of installing mods coincidently with doing major repairs that are due (if any). For example, if your balancer is in poor shape or nearing it's end, I would consider a medium/mild cam upgrade + oil pump + front main seal because you're already there. That's what I did at least. I was obsessed with getting a cam, and you would benefit since you've done other bolt-ons to benefit for better pumping efficiency. But your goals and what you like is key of course.
Old Oct 1, 2019 | 02:06 PM
StingrayRebel's Avatar
StingrayRebel
what kind of supercharger and how far would you want to go with it power wise?
Old Oct 3, 2019 | 04:31 PM
DrRaySomeDay's Avatar
DrRaySomeDay
I had a 150 wet shot with an ECS mail order tune on my 2001 Auto w/ headers and Vararam intake before going with a supercharger.
A good used wet kit and 10lb bottle can be found on here or LS1tech at around half the cost of new. DIY Install was not any worse than HID headlights. I didn't have any gadgets like a remote bottle opener or bottle heater on mine. A bottle heater would be nice because after 3-4 sprays on a 10lb bottle I could tell there was less bottle pressure and the "hit" is a bit weaker, but I heard wiring one up was a nightmare. I just unhooked the bottle and gave it a hot water bath if I knew I was low and planning on spraying.
I went through about 10 bottles in year and a half or so at around $40-50 a bottle. No track sprays, so I'm not sure if you'd go through more/less than that. 150hp is the most I'd go, just have ECS get you a mail order tune for a 150 wet shot and have fun while you save up for a supercharger kit!
Old Oct 3, 2019 | 04:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 on saving for a S/C
Cam/gears etc will cost you at least the same in the end....I love a good NA motor but honestly SC is the best way to go
Old Oct 3, 2019 | 06:18 PM
gimp's Avatar
gimp
I have a supercharger. They're great for street use, less awesome for track use unless you're willing to commit full-bore to all the supporting mods. We still don't know OPs goals beyond "more power."
To What’s next for mods ?
