So, last night the wife and I headed out for a after dinner rip in the vette (1998)
the sun was setting we were loosing day light and the headlights were turned on all was good, I turned the blinker on heading into the neighborhood and it happened! Both indicators on the dash started blinking a lot faster then normal, so I pulled into the drive way and got out to see if any bulbs were not working? They all looked good! I turned the headlights off and the whole dash started blinking! AT THIS POINT IM SCRATCHING MY HEAD! Mind you I did replace the Hi/low blinker switch with a brand new one this spring ( about 5000 miles ago)
So what direction should I go , thanks in advance, cruzbox
Load test your battery, seems you may have a low voltage problem, at a loss why your dash would start blinking when you turned off your headlights, hopefully somebody has experienced this same problem and will post a possible solution to your problem.
