ebcm
Old Oct 4, 2019 | 04:24 PM
Joseph Widerynski's Avatar
Joseph Widerynski
3rd Gear
Default ebcm
Recently was riding down the FWY in my 2004 Z06. Info on dash said I had a problem with the ABS (?) and said take it to the dealer. Dealer indicated the part I needed was 10343433 electronic break control module. Dealer said they
this part was not longer available via Chevrolet. Needed after market model. Looked around apparently a new ECBM was no longer available. Checked the forum this issue was discussed years ago. Anyone have any suggestions on
the EBCM issue as of late? Where shall I start. Any help would be appreciated.
Joe
Old Oct 4, 2019 | 04:50 PM
jackthelad's Avatar
jackthelad
Start with VetteNuts - they are Vette dismantlers. https://vettenuts.net
Old Oct 4, 2019 | 05:31 PM
mmartinez's Avatar
mmartinez
There are rebuilders for the ebcm, do a internet search or maybe somebody on this forum knows who can rebuild yours, all is not lost.
Old Oct 4, 2019 | 07:51 PM
01pewtervert's Avatar
01pewtervert
Pull and post the trouble codes from the IPC. If you have C1214, which is very common, it most likely can be repaired by a ABS module repair shop. If you have C1255, that is usually a death sentence.
Old Oct 5, 2019 | 02:24 AM
Joseph Widerynski
3rd Gear
Thank you for your suggestions. Will follow thru and post the findings.
Joe
Old Oct 9, 2019 | 02:36 PM
STRMLNE's Avatar
STRMLNE
If it’s 1214 absfixer.com will repair your model for $150
Old Oct 9, 2019 | 08:47 PM
Markes's Avatar
Markes
Had mine repaired/rebuilt here:
https://www.ebay.com/itm/280776454190
Started to get ABS - Traction Control codes (can't remember if it was a C1214 or a C1255). Someone on this forum recommended looking on the net for a repair/rebuild service. Most were $150 (or more) so I checked out Ebay.
I removed the module from the pump and send it to the repair service. They shipped it back in the same package I sent (make sure you pack it good in a decent box).
I sent mine out (USPS Priority) on the 11th and received it back on the 18th. Installed the rebuilt module the day it arrived and no ABS - Traction Control codes. That was one year ago and no codes since.
It only cost $50.00 (with free return shipping) for the service.
*I have no connection to the repair service other than having them repair/rebuild my ebcm module
To ebcm
